Civil Engineering Association eBooks General Books Sound Insulation in Buildings
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
02-04-2018, 08:15 PM
Author(s)/Editor(s): Jens Holger Rindel | Size: 15 MB | Format: PDF | Quality: Original preprint | Publisher: CRC Press | Year: 2018 | pages: 477 | ISBN: 1498700411, 9781498700412, 9781498700429, 149870042X
[Image: 81101646432643676341.jpg]
The book explains sound insulation in buildings at a level suitable for both graduate students and expert consultants.
Theoretical models are set out for sound transmission in buildings, with an emphasis on thick and heavy constructions. Thus, the description is not restrained by the common assumption of bending waves which is characteristic of thin plates, only. A general description is provided, with the modal density in the structures as a key parameter. At low frequencies statistical energy analysis is replaced by modal energy analysis. Sound transmission through windows and facades is represented by a model that allows any angle on incidence, including the special case of grazing incidence. One chapter is devoted to the subjective evaluation of sound insulation, particularly noise from neighbours, and how this can be applied in a sound classification scheme for dwellings. Measurement methods in building acoustics are presented with emphasis on modern methods using MLS signals or sine sweeps. The analysis and estimation of measurement uncertainty is discussed in detail. In a final chapter examples of experimental buildings with high sound insulation are explained.
Thanks to Original Uploader
[-] The following 19 users Like cace-01's post:19 users Like cace-01's post
  • cheosmith, oanm2000, gulilero, milova, emmi, zrilek, PinkPant, amindoxiti, blaze, sabooryan, Dell_Brett, Nita1391, Trishu999, munycamsec, rendel_©, febo927, cargadory2k, rezart, maad59
 bhuiyan
Bangladesh
User ID: 20002
Threads: 5
Likes: 46 in 11 posts
Given Likes: 129
03-01-2018, 06:01 AM
Not able to get the download link.
TIA
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,985 in 4,091 posts
Given Likes: 612
03-01-2018, 06:18 AM
Why? I pressed GET and after a few seconds the download begins.
  HOUSING AND SOUND INSULATION ir_71 0 1,428 04-19-2011, 09:51 AM
  Insulation Handbook ivanveliki 2 2,284 02-28-2011, 05:36 AM
  Guide for Sound Insulation in wood frame construction E123 1 1,910 02-19-2011, 06:43 AM
  Sound Control in Buildings ir_71 1 1,756 11-14-2010, 11:48 AM
