Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Standard Penetration Test Procedures and Effects in Sands of Overburden, r
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 70
Likes: 1,673 in 128 posts
Given Likes: 429
09-17-2017, 08:16 AM (This post was last modified: 09-17-2017, 08:17 AM by gianniorlati. Edit Reason: N/A )
Standard Penetration Test Proceures and the Effect on Sands of Overburden Pressure, relative Density, Ageing and Overconsolidation
  • Author(s): A. W. Skempton
  • Published By: Geotechnique
  • Published Year: 1986
  • Size: 1.70 MB
  • Quality: Scanner(OCR)
  • Abstract: Granted that good site control is exercised in carrying out the standard penetration test the energy delivered
    to the sampler, and therefore the blow count obtained in any given sand deposit at a particular effective overburden pressure, can still vary to a significant extent depending on the method of releasing the hammer, on the type of anvil and on the length of rods (if less than 10 m).
    For consistency it is essential to correct the observed blow count N to the value which would have been measured using a specified rod energy.
    A recommended value, which should be recognized internationally, is 60% of the free-fall energy of the standard hammer weight and drop.
    The corrected blow count is then designated as N 60 and the normalized value (N 1)60 at unit effective pressure ( 1 kg/cm 2 or 100 kPa) may be regarded as a basic characteristic of the sand.
[-] The following 13 users Like gianniorlati's post:13 users Like gianniorlati's post
  • blaze, civilfafa, freequo, PinkPant, subin91, zrilek, nhim4mat2006, mgdario, Dell_Brett, Grunf, Trishu999, scorpion07, sacem
  Strength and Dilatancy of Sands and other Paper from M. D. Bolton gianniorlati 0 1,320 09-17-2017, 07:42 AM
Last Post: gianniorlati
  NYDOT: SOIL MECHANICS LABORATORY TEST PROCEDURES tuanpecc1 2 3,232 08-25-2012, 05:24 AM
Last Post: shadabg
