Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Vibrations and Stability of Complex Beam Systems
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
02-19-2015, 07:45 AM
Author: Vladimir Stojanovic and Predrag Kozic | Size: 19 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2015 | pages: 166 | ISBN: 3319137662, 3319137689, 9783319137667, 9783319137674
[Image: 15204182981286086703.jpeg]
This book reports on solved problems concerning vibrations and stability of complex beam systems. The complexity of a system is considered from two points of view: the complexity originating from the nature of the structure, in the case of two or more elastically connected beams; and the complexity derived from the dynamic behavior of the system, in the case of a damaged single beam, resulting from the harm done to its simple structure. Furthermore, the book describes the analytical derivation of equations of two or more elastically connected beams, using four different theories (Euler, Rayleigh, Timoshenko and Reddy-Bickford). It also reports on a new, improved p-version of the finite element method for geometrically nonlinear vibrations. The new method provides more accurate approximations of solutions, while also allowing us to analyze geometrically nonlinear vibrations. The book describes the appearance of longitudinal vibrations of damaged clamped-clamped beams as a result of discontinuity (damage). It describes the cases of stability in detail, employing all four theories, and provides the readers with practical examples of stochastic stability. Overall, the book succeeds in collecting in one place theoretical analyses, mathematical modeling and validation approaches based on various methods, thus providing the readers with a comprehensive toolkit for performing vibration analysis on complex beam systems.
Thanks to Original Uploader
[-] The following 18 users Like cace-01's post:18 users Like cace-01's post
  • PinkPant, jcbv, blaze, Mohammad6299, zrilek, oanm2000, slowet, gulilero, Dell_Brett, eliseo.as, Veggeta, jfjdm, malc, knrsa, Jackass, agarciam2, cristi, kowheng
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
02-19-2015, 04:27 PM
[-] The following 3 users Like Veggeta's post:3 users Like Veggeta's post
  • oanm2000, PinkPant, draluka
  The dynamic stability of elastic systems - 1964 febo927 1 1,750 07-04-2018, 04:55 AM
Last Post: axcel
  Mechanical Systems: A Unified Approach to Vibrations and Controls ssobhan 0 1,516 08-08-2015, 07:00 AM
Last Post: ssobhan
  Random Vibrations: Analysis of Structural and Mechanical Systems Grunf 5 3,704 12-17-2014, 12:45 PM
  Vibrations of mechanical systems with regular structure Grunf 4 3,284 08-07-2014, 09:20 PM
Last Post: odiclas
  Optimal Control Theory for the Damping of Vibrations of Simple Elastic Systems david-smith 2 2,231 03-23-2013, 02:20 PM
Last Post: arshiakh
  Applications of Nonlinear Dynamics: Model and Design of Complex Systems struceng 3 3,493 01-14-2013, 05:39 AM
Last Post: pezhmankhan
  Nonlinear Vibrations and Stability of Shells and Plates Flexi 3 3,254 03-19-2011, 06:52 AM
