Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Mechanical behavior of RC walls under seismic activity strenghtened with CFRP
02-09-2015, 07:13 AM (This post was last modified: 02-09-2015, 01:27 PM by oanm2000.)
Author: Samiullah Qazi | Size: 10.8 MB | Format: PDF | Quality: Unspecified | Year: 2013 | pages: 197
[Image: 91337856730634278621.jpg]
Recent earthquake surveys have revealed the significance of RC walls as an integral part of structures. It reduces the structure damage to some extent. However, like other structural member they too are vulnerable. Researchers on basis of their post eartthquake survey and laboratary experiments have concluded that the RC wall buildings sustained damage, mainly due to design and construction work flaws. In this thesis experimental result of shear walls is discussed. They were designed under-reinforced to fail in shear in ase of short wall and in flexure for slender walls. Three out of these six specimens, in each case, were strengthened externally with CFRP strips bonded to wall panel and mesh anchors installed at wall foundation joint. Two specimens, one RC and one CFRP retrofitted (short and slender wall each), were subjected to static load test and three specimens, one RC and two to three CFRP retrofitted, were subjected to quasi static cyclic load tests. The test result analysis discussion includes failure mode, stiffness, ultimate load capacity, ductility, and energy dissipation
  • subin91, Dell_Brett, cace-01, PinkPant, oanm2000, bridgeengineer, Veggeta, blaze, vardan, chrono146, ykhackhack, gulilero, sodapas
 Veggeta
Guatemala
User ID: 114
Threads: 103
Likes: 4,273 in 520 posts
Given Likes: 402
02-09-2015, 04:42 PM
[-] The following 3 users Like Veggeta's post:3 users Like Veggeta's post
  • PinkPant, ruaumoko, lesgiu
Users browsing this thread: 5 Guest(s)
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,905 02-09-2015, 07:24 AM
  Finite Element Analysis of the Seismic Behavior of Guyed Masts TAFATNEB 0 1,689 12-26-2014, 09:54 PM
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,800 10-08-2014, 02:00 PM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,649 05-30-2014, 02:05 PM
  BEAM - COLUMN CONNECTION FLEXURAL BEHAVIOR AND SEISMIC COLLAPSE PERFORMANCE OF CONCEN TAFATNEB 0 1,673 04-26-2014, 09:52 AM
  The Seismic Performance of Coupled Reinforced Concrete Walls TAFATNEB 0 1,692 04-21-2014, 10:59 PM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,682 04-19-2014, 08:58 AM
