Civil Engineering Association eBooks Traffic Engineering AASHTO - AASHTO Provisional Standards
 Saze808
User ID: 32657
Threads: 46
Likes: 423 in 62 posts
Given Likes: 91
09-14-2014, 12:35 PM (This post was last modified: 09-14-2014, 10:23 PM by Dell_Brett.)
AASHTO Provisional Standards, 2009 Edition
Author: AASHTO | Size: 25 MB | Format: PDF | Quality: Original preprint | Publisher: AASHTO | Year: 2009 | pages: 361 | ISBN: 9781615831203, 9781405187404
[Image: 31907337193425232937.jpg]
This 13th Edition of the AASHTO Provisional Standards contains a complete set of 41 provisional materials specifications and test methods. All Provisional Standards are approved for publication by the AASHTO Highway Subcommittee on Materials. Provisional Standards are standards which have been adopted by the Highway Subcommittee on Materials on a temporary basis for a maximum of eight years. A chronology of the year-to-year status of the Provisional Standards during the past eight years is included. At any time during the eight-year period, the Subcommittee can ballot to convert a Provisional Standard into a Full Standard. The Subcommittee, so far, has converted 58 Provisional Standards into Full Standards. These Standards are now regularly published in the AASHTO Standard Specifications for Transportation Materials and Methods of Sampling and Testing.
Content:
Front Matter
• Table of Contents
•Aggregates MP 16-07 - Reclaimed Concrete Aggregate for Use as Coarse Aggregate in Hydraulic Cement Concrete
TP 77-09 - Specific Gravity and Absorption of Aggregate by Volumetric Immersion Method
•Bituminous Materials MP 15-09 - Use of Reclaimed Asphalt Shingles as an Additive in Hot Mix Asphalt (HMA)
PP 53-09 - Design Considerations When Using Reclaimed Asphalt Shingles (RAS) in New Hot Mix Asphalt (HMA)
PP 60-09 - Preparation of Cylindrical Performance Test Specimens Using the Superpave Gyratory Compactor (SGC)
PP 61-09 - Developing Dynamic Modulus Master Curves for Hot Mix Asphalt (HMA) Using the Asphalt Mixture Performance Tester (AMPT)
PP 62-09 - Developing Dynamic Modulus Master Curves for Hot Mix Asphalt (HMA)
TP 62-07 - Determining Dynamic Modulus of Hot Mix Asphalt (HMA)
TP 63-09 - Determining Rutting Susceptibility of Hot Mix Asphalt (HMA) Using the Asphalt Pavement Analyzer (APA)
TP 68-04 - Density of In-Place Hot Mix Asphalt (HMA) Pavement by Electronic Surface Contact Devices
TP 70-09 - Multiple Stress Creep Recovery (MSCR) Test of Asphalt Binder Using a Dynamic Shear Rheometer (DSR)
TP 71-09 - Evaluation of Superpave Gyratory Compactor (SGC) Internal Angle of Gyration Using Simulated Loading
TP 72-08 - Quantitative Determination of the Percentage of Lime in Hot Mix Asphalt (HMA)
TP 78-09 - Detecting the Presence of Phosphorous in Asphalt Binder
TP 79-09 - Determining the Dynamic Modulus and Flow Number for Hot Mix Asphalt (HMA) Using the Asphalt Mixture Performance Tester (AMPT)
•Box Culvert, Culvert Pipe, and Drain Tile PP 63-09 - Pipe Joint Selection for Highway Culvert and Storm Drains
•Concrete PP 54-06 - Match Curing of Concrete Test Specimens
PP 58-08 - Static Segregation of Hardened Self-Consolidating Concrete (SCC) Cylinders
TP 59-00 - Determining Air Content of Hardened Portland Cement Concrete by High-Pressure Air Meter
TP 64-03 - Predicting Chloride Penetration of Hydraulic Cement Concrete by the Rapid Migration Procedure
TP 73-09 - Slump Flow of Self-Consolidating Concrete (SCC)
TP 74-09 - Passing Ability of Self-Consolidating Concrete (SCC) by J-Ring
TP 75-08 - Air-Void Characteristics of Freshly Mixed Concrete by Buoyancy Change
TP 80-09 - Visual Stability Index (VSI) of Self-Consolidating Concrete (SCC)
•Metallic Materials and Coatings for Bridges MP 12-04 - Detectable Warning Surfaces
MP 13M/MP 13-04 - Stainless Clad Deformed and Plain Round Steel Bars for Concrete Reinforcement
MP 18M/MP 18-09 - Uncoated, Corrosion-Resistant, Deformed and Plain Alloy, Billet-Steel Bars for Concrete Reinforcement and Dowels
PP 45-07 - Qualification of Deformed and Plain Steel Bar Producing Mills
PP 55-06 - Overcoating Field Test Program for Evaluating Protective Coatings on Existing Bridges or Salvaged Beams
•Pavement Structures MP 11-08 - Inertial Profiler
MP 14-08 - Smoothness of Pavement in Weigh-in-Motion (WIM) Systems
MP 17-08 - Pavement Ride Quality When Measured Using Inertial Profiling Systems
PP 44-01 - Quantifying Cracks in Asphalt Pavement Surface
PP 49-08 - Certification of Inertial Profiling Systems
PP 50-07 - Operating Inertial Profilers and Evaluating Pavement Profiles
TP 76-09 - Measurement of Tire/Pavement Noise Using the On-Board Sound Intensity (OBSI) Method
•Quality Assurance PP 56-06 - Evaluating the Engineering and Environmental Suitability of Recycled Materials
PP 57-06 - Establishing Requirements for and Performing Equipment Calibrations, Standardizations, and Checks
•Soils MP 9-06 - Compost for Erosion/Sediment Control (Filter Berms and Filter Socks)
MP 10-03 - Compost for Erosion/Sediment Control (Compost Blankets)
PP 59-09 - Coal Combustion Fly Ash for Embankments
[-] The following 7 users Like Saze808's post:7 users Like Saze808's post
  • Jackass, jfjdm, malc, PinkPant, bridgeengineer, azhdar1031, utan
  AASHTO - Mechanistic-Empirical Pavement Design Guide - A Manual of Practice cace-01 2 2,659 05-29-2018, 03:30 PM
Last Post: axcel
  AASHTO - AASHTO Transportation Glossary Saze808 2 2,330 09-30-2017, 04:09 PM
  AASHTO - Highway Safety Manual Saze808 2 2,616 03-13-2016, 09:17 PM
  AASHTO - Guide on Evaluation and Abatement of Traffic Noise Saze808 1 1,944 09-17-2014, 08:27 AM
Last Post: pezhmankhan
  AASHTO - Highway Drainage Guidelines Saze808 1 2,362 09-15-2014, 08:33 AM
  AASHTO - Guidelines for Vegetation Management Saze808 0 1,512 09-14-2014, 12:53 PM
Last Post: Saze808
  AASHTO - Guide to Wetland Mitigation Issues for Transportation Designers Saze808 0 1,508 09-14-2014, 12:49 PM
Last Post: Saze808
