Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SHEAR STREN GTH OF CIRCULAR REINFORCED CONCRETE COLUMNS
06-01-2014, 03:41 PM
Author: Lisa Y. Choe | Size: 29 MB | Format: PDF | Quality: Unspecified | Publisher: The Ohio State University | Year: 2006 | pages: 77
In this research, the influence of parameters on the shear strength of circular reinforced concrete columns is investigated based on the evaluation of experimental data from numerous column tests. Key parameters investigated in shear strength model are the column aspect ratio, axial load, amount of transverse reinforcement, and deformation ductility demand. An examination of existing design equations reveals wide difference in predicted response. Also, the shear strength model for rectangular reinforced concrete columns proposed by Sezen et al. (2004) is used for evaluating whether it is applicable to predict the shear strength of circular columns. The proposed shear strength equation by
Sezen et al. (2004) is composed of additive contributions from concrete and transverse reinforcement, and is a function of displacement ductility. The model proposed by Sezen et al. (2004) is compared with contemporary code provisions and previously proposed models using the available column test data and is shown to result in improved accuracy.
  • vardan, blaze, rezart, ting tsai huang, inge911, jacs1976, malc, Mohammad6299, nima_b12, sodapas
  PUNCHING SHEAR STRENGTH AND DE FORMATION CAPACITY OF FIBER REINFORCED CONCRETE SLAB-C TAFATNEB 0 1,632 06-01-2014, 03:30 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,677 05-09-2014, 04:00 PM
  In Situ Dynamic Characteristics of Reinforced Concrete Shear Wall Buildings mybest 1 2,261 04-08-2014, 10:33 AM
Last Post: Grunf
  EFFICIENT FINITE ELEMENT MODELING OF REINFORCED CONCRETE COLUMNS CONFINED WITH FIBER TAFATNEB 0 1,651 03-31-2014, 10:33 PM
  P-DELTA EFFECTS OX THE INELASTIC SEISMIC RESPONSE OF REINFORCED CONCRETE SHEAR WALL B TAFATNEB 0 1,650 11-23-2013, 01:27 PM
  PERFORMANCE ASSESSMENT OF SHEAR-CRITICAL REINFORCED CONCRETE PLANE FRAMES TAFATNEB 0 1,684 11-10-2013, 09:54 PM
  Behavior and Vulnerability of Reinforced Masonry Shear Walls TAFATNEB 0 1,689 11-02-2013, 10:54 AM
