Civil Engineering Association eBooks Codes, Manual & Handbook CIRIA: Constrution Industry Research and Information Association
Thread Closed
 ribak
User ID: 207
Threads: 49
Likes: 423 in 37 posts
Given Likes: 15
03-20-2009, 12:09 PM (This post was last modified: 01-26-2015, 05:01 PM by usman.)
CIRIA - C534 - Civil Engineering Design and Construct
A Guide to Integrating Design into the Construction Process
[Image: 91670504550134569040.jpg]
By G. Lafford, et al
* Publisher: Construction Industry Research & Information Association (CIRIA)
* Number Of Pages: 92
* Publication Date: 2001-01-09
* ISBN-10 / ASIN: 0860175340
* ISBN-13 / EAN: 9780860175346
* Binding: Paperback
Product Description:
This publication is a guide to best practice in managing the project process in civil engineering design and construct (D&C) projects. It discusses the issues to be addressed when managing design and explains the attitudes and practices that are recommended to enable projects to succeed. It is intended to increase awareness and understanding of the issues involved, identifying what decisions need to be made, when and why. Differences between D&C and traditional procurement routes are highlighted along with contractual issues. "Design and construct" is taken to be a generic term encompassing the whole family of design, construct, finance, own, operate and transfer procurement strategies, in which one party is responsible for both designing and constructing a facility. This includes projects procured under the Private Finance Initiative (PFI). Considerable emphasis is placed on imparting awareness of the importance of the designer-constructor interface as, in a D&C project, the most critical lines of communication are at this interface. As well as describing contractual frameworks, this guide also contains management toolboxes for reference. It is a working document that will assist those at a senior level (clients, contractors and consultants alike) who have to make crucial decisions affecting the outcome of a project.
[-] The following 20 users Like ribak's post:20 users Like ribak's post
  • kowheng, aami32, avscorreia, oanm2000, Dell_Brett, oreslaw, zrilek, sivlad, dbsimon29, cesar3226, knrsa, slowet, wobmot, malc, blaze, Trishu999, narendra, stigtg, krishna22045, dinu69in
 choonguan
User ID: 686
Threads: 16
Likes: 513 in 24 posts
Given Likes: 44
09-01-2009, 05:05 AM (This post was last modified: 05-06-2011, 11:00 PM by usman.)
CIRIA - C660 - Early-Age Thermal Crack Control in Concrete
This guide provides a method for estimating the magnitude of crack-inducing strain and the risk of cracking; and where cracking is predicted guidance is provided on the design of reinforcement to control crack widths. For specific situations where cracking should be avoided, or where the use of reinforcement to achieve acceptable crack widths is uneconomic or impractical, measures are described to minimise the risk including selection of materials and mix design, planning pour sizes and construction sequence, the use of insulation to reduce thermal gradients, the use of movement joints, and cooling of the concrete either prior to placing or in situ.
Publisher: CIRIA
ISBN: 978-8-86107-660-2
screenshots:
[Image: 5gbg15b87drcnrkmwx.jpg]
Download Links:
[-] The following 28 users Like choonguan's post:28 users Like choonguan's post
  • kowheng, kowheng, vvvv, vvvv, Dell_Brett, Dell_Brett, ajmf77, ajmf77, zrilek, zrilek, baikur, baikur, mohcivil, mohcivil, peixoto, jf28, tang1942, ruaumoko, salahcivil, chenamoy, blaze, Eaky, ssi3k, oreslaw, sivlad, cesar3226, azharb, p_vosoughi
 timosi™
User ID: 3890
Threads: 143
Likes: 5,532 in 394 posts
Given Likes: 1812
09-14-2009, 11:22 AM (This post was last modified: 05-06-2011, 11:09 PM by usman.)
CIRIA - Bridges: Design for Improved Buildability
[Image: owun88k9en78oxtm0m3.jpg]
Info:
Publisher: CIRIA, 1996
ISBN: 9780860174400
Length: 149 pages
Pdf: 5.9 Mb
Prepared for use by bridge designers, working for either the owner or a constructor. The inter-relationships between the design and the logistics of construction are highlighted. Advice is given on conceptual issues and the selection of details to achieve structures which are easier and cheaper to build.
Download Link:
I wish that it will be nerver died.
regard
timosi
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 16 users Like timosi™'s post:16 users Like timosi™'s post
  • zrilek, zrilek, Mohoh77, toa011, ilgar, Adam Smith, triance, ssi3k, oanm2000, blaze, oreslaw, sivlad, cesar3226, slowet, malc, vinnunsam
 timosi™
User ID: 3890
Threads: 143
Given Likes: 1812
09-25-2009, 04:40 AM (This post was last modified: 05-06-2011, 10:43 PM by usman.)
CIRIA - R110 - Design Of Reinforced Flat Slabs To BS 8110
1.Follows the rules
4.Do not spam
[-] The following 25 users Like timosi™'s post:25 users Like timosi™'s post
  • ajmf77, ajmf77, zrilek, zrilek, nnn012, nnn012, babak, amira, NasrEdeen, prapruk, Nilupa, vantoancons, tang1942, jf28, ngcanhtoan, kerenski_t, VANTRIXD, blaze, oreslaw, dbsimon29, sivlad, cesar3226, knrsa, femana, techno
 username123
User ID: 7763
Threads: 2
Likes: 269 in 13 posts
Given Likes: 2
10-31-2009, 01:43 AM (This post was last modified: 05-06-2011, 10:06 PM by usman.)
CIRIA - C517 - Temporary Propping of Deep Excavation
Gives guidance for temporary propping systems for deep excavations which will lead to greater efficiency in their use. The conclusion to the report includes a summary of the main recommendations from the study.
[-] The following 45 users Like username123's post:45 users Like username123's post
  • meditation, meditation, kowheng, kowheng, niki102, niki102, ziggywas1, ziggywas1, chenamoy, Grunf, baikur, isurya, zrilek, adi04, pousin, hessian, jcaz15, sheb101, cristi, aleph177, dbsimon29, toa011, drim_w3, Svetoslav, cigutierrezg, oanm2000, Dell_Brett, ilgar, ssi3k, Geotechman, roaming79, dinu69in, malc, Evandrojr, blaze, oreslaw, sivlad, gibran, cesar3226, knrsa, Trishu999, narendra, pmg814, geomahesh, febo927
 epee
User ID: 5696
Threads: 7
Likes: 307 in 32 posts
Given Likes: 13
11-03-2009, 10:59 AM (This post was last modified: 05-06-2011, 09:56 PM by usman.)
CIRIA - 580 - Embedded Retaining Walls - Guidance for Economic Design
[-] The following 27 users Like epee's post:27 users Like epee's post
  • kowheng, JAB91076, robertsas, Gabemzaman, sheb101, Dell_Brett, mskhaled, ziggywas1, jacs127, jcaz15, chenamoy, Adam Smith, ssi3k, hrezaei, toa011, blaze, mahfuzbangla, oreslaw, zrilek, sivlad, miquan, cesar3226, wobmot, oanm2000, narendra, pmg814, geomahesh
 username123
User ID: 7763
Threads: 2
Given Likes: 2
11-18-2009, 03:21 PM (This post was last modified: 05-06-2011, 10:24 PM by usman.)
CIRIA - R25 Site Investigation Manual
[Image: 36572278144565450185.jpg]
Provides detailed technical guidance on the scope, planning, organisation, and appraisal of site investigations for civil engineering and building projects. The report relates generally to site investigation, although there is an emphasis throughout on geotechnical aspects, referred to as ground investigation. The site investigation process is described, and guidance is given on the practical aspects of field work, laboratory testing of materials, interpretation of results and application to the design of foundations.
[-] The following 40 users Like username123's post:40 users Like username123's post
  • kowheng, ziggywas1, oanm2000, Gabemzaman, Dell_Brett, robertsas, abudabeeja, i_kabir, isurya, zrilek, adi04, jacs127, daywalker, civilteam, Medve, mz55, sheb101, amrshana, cesar3226, labqIM, chenamoy, vantoancons, rudyhera03, Mohoh77, toa011, mecheil.edwar, utan, ha893459, blaze, mahfuzbangla, oreslaw, dbsimon29, sivlad, knrsa, Trishu999, narendra, dinu69in, pmg814, geomahesh, febo927
 Gabemzaman
User ID: 2838
Threads: 20
Likes: 1,073 in 79 posts
Given Likes: 379
11-19-2009, 03:43 AM (This post was last modified: 05-06-2011, 10:23 PM by usman.)
CIRIA - Guide 1- Anchor Block Design
[Image: 09957153367268228562.jpg]
A Guide To The Design of Anchor Blocks For Post-Tensioned Prestressed Concrete
[-] The following 20 users Like Gabemzaman's post:20 users Like Gabemzaman's post
  • robertsas, kowheng, ziggywas1, Dell_Brett, baikur, zrilek, thebeatles, pousin, ruaumoko, Nilupa, bhawk0, henrycv, RedHorse, jf28, blaze, mahfuzbangla, oreslaw, sivlad, cesar3226, malc
 Gabemzaman
User ID: 2838
Threads: 20
Given Likes: 379
11-19-2009, 04:03 AM (This post was last modified: 05-06-2011, 10:23 PM by usman.)
CIRIA - R102 - Design of Shear Wall Buildings
CIRIA R 102 - Design of Shear Wall Buildings
by A.W. Irwin
[Image: 20638806170969560859.jpg]
[-] The following 31 users Like Gabemzaman's post:31 users Like Gabemzaman's post
  • kowheng, essam2109, mig21, chenamoy, baikur, cristi, wa_sin_29, fnoto, bubieng, moh_towhid, simanta, zrilek, jcoronellr, subin91, Ezop, hans01, jf28, dinu69in, thebeatles, salahcivil, mz55, derwin, ruaumoko, einarmag, rezart, stigtg, blaze, Eaky, mahfuzbangla, sivlad, toa011
 gafi
User ID: 1273
Threads: 20
Likes: 323 in 29 posts
Given Likes: 326
11-19-2009, 08:34 AM (This post was last modified: 05-06-2011, 11:02 PM by usman.)
CIRIA - Design of Deep Beams in Reinforced Concrete
[-] The following 9 users Like gafi's post:9 users Like gafi's post
  • vvvv, Dell_Brett, pousin, blaze, Eaky, oreslaw, zrilek, sivlad, knrsa
Pages (9): 1 2 3 4 5 6 7 8 9 Next »
  NAAMM National Association of Architectural Metal Manufacturers deviationz 0 1,852 07-28-2010, 03:10 PM
Last Post: deviationz
