Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis SEISMIC DESIGN, TESTING AND ANALYSIS OF REINFORCED CONCRETE WALL BUILDINGS
05-09-2014, 04:36 PM
Author: Marios Panagiotou | Size: 4.1 MB | Format: PDF | Quality: Unspecified | Publisher: UNIVERSITY OF CALIFORNIA, SAN DIEGO | Year: 2008 | pages: 290
[Image: 24306360444254800601.jpg]
Abstract:
Large investments have recently been made for the construction of new medium- and highrise buildings in California. In many cases performance-based designs have been the preferred method for these buildings. A main consideration in performance-based seismic design is the estimation of the likely development of structural and nonstructural damage limit-states given a hazard level. For this type of buildings efficient modeling techniques are required able to compute
the response at different performance states. A research work was conducted at University of California San Diego (UCSD) on the i) seismic design, ii) experimental response and iii)
computational modeling of medium- and high-rise reinforced concrete wall buildings. In the first part of this work a displacement-based seismic design method for use within performance-based is developed. Capacity design is used to control the mechanism of inelastic deformation. Based on
principles of plastic analysis and structural dynamics the new formulation allows the computation of the effects of system overstrength and of the higher modes of response. Equal emphasis is given to displacement, force and acceleration demand parameters. The ground motion destructiveness potential is also determined. Application of the method to reinforced concrete wall buildings is
discussed. The method is validated with the experimental response of a full-scale 7 story building.
In addition a dual plastic hinge design concept for improving the performance and optimizing the construction of high-rise buildings is presented. The second part presents the experimental research program, with extensive shake table tests, of a full-scale 7-story reinforced concrete wall
building slice, that was conducted at UCSD. The base shear coefficient obtained by the proposed method, of the first part of the research work, described above was 50% of that required by the equivalent static method prescribed by the ASCE-7 code. In spite of the reduced amount of longitudinal reinforcing steel, all performance objectives were met. The response of the building was significantly influenced, as expected, by the interaction of the main lateral force resisting wal
  • vardan, blaze, malc, rezart, ruaumoko, faros3000, ting tsai huang, PinkPant, mgdario
  Non-linear analysis of a collapsed reinforced concrete chimney mybest 1 3,862 11-06-2020, 08:17 AM
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,959 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE TAFATNEB 0 1,886 03-27-2015, 03:16 PM
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,805 03-27-2015, 11:44 AM
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,782 09-02-2014, 08:10 AM
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 1,761 08-31-2014, 07:45 AM
  Design and Analysis of Complex D-Regions in Reinforced Concrete Structures nima_b12 1 2,115 07-21-2014, 01:23 PM
Last Post: apocalipse
