Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis BEAM - COLUMN CONNECTION FLEXURAL BEHAVIOR AND SEISMIC COLLAPSE PERFORMANCE OF CONCEN
04-26-2014, 09:52 AM
BEAM - COLUMN CONNECTION FLEXURAL BEHAVIOR AND SEISMIC COLLAPSE PERFORMANCE OF CONCENTRICALLY BRACED FRAMES
Author: CHRISTOPHER D. STOAKES | Size: 7.1 MB | Format: PDF | Quality: Unspecified | Publisher: University of Illinois at Urbana-Champaign, | Year: 2012 | pages: 232
[Image: 89024399938255382569.png]
This dissertation investigates the flexural behavior of beam-column connections with gusset plates and their ability to improve the seismic collapse performance of concentrically braced frames. Previous experimental and field observations demonstrated that reserve lateral force-resisting capacity due to the flexural strength of connections outside the primary lateral force-resisting system of steel frames can maintain structural stability if the primary system is damaged. Several experimental studies were conducted to quantify the flexural behavior of these connections, but there has only been limited investigation of beam-column connections with
gusset plates.
  • blaze, malc, isurya, slowet, subin91, zrilek, rezart, ting tsai huang, vardan
  Seismic Performance Assessment and Probabilistic Repair Cost Analysis of Precast Conc TAFATNEB 0 1,573 07-03-2015, 10:30 PM
  Mechanical behavior of RC walls under seismic activity strenghtened with CFRP TAFATNEB 1 1,847 02-09-2015, 04:42 PM
Last Post: Veggeta
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,906 02-09-2015, 07:24 AM
  Finite Element Analysis of the Seismic Behavior of Guyed Masts TAFATNEB 0 1,689 12-26-2014, 09:54 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,659 05-09-2014, 04:00 PM
  EVALUATION OF THE SEISMIC PERFORMANCE OF REINFORCED CONCRETE BUILDINGS TAFATNEB 0 1,623 05-09-2014, 11:35 AM
  The Seismic Performance of Coupled Reinforced Concrete Walls TAFATNEB 0 1,692 04-21-2014, 10:59 PM
