Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis The Seismic Performance of Coupled Reinforced Concrete Walls
04-21-2014, 10:59 PM
Author: Jacob A. Turgeon | Size: 15.4 MB | Format: PDF | Quality: Unspecified | Publisher: University of Washington | Year: 2011 | pages: 436
[Image: 59027066544807134627.jpg]
Reinforced concrete core walls are used commonly in modern building construction as the primary lateral-load resisting system. Common core wall con gurations include solid walls in one direction and walls with openings in the orthogonal direction to access ele-vators or to meet architectural requirements. Therefore, in the orthogonal direction, the walls are typically coupled together by reinforced concrete \coupling" beams. A signi - cant amount of research has focused on the design of coupling beams to ensure that they exhibit ductile response through multiple cycles to large drift demands. However, only a few research studies have investigated the seismic behavior of coupled wall systems, and most of these previous studies have considered coupled-walls in low-rise structures. Most
coupled walls are used in elevator cores, which are more typical in mid- to high-rise con- struction. A research study was undertaken by faculty and students at the Universities of Washington and Illinois to speci cally investigate this category of structural system. The advanced testing capabilities of the NEES University of Illinois at Urbana-Champaign (UIUC) testing facility permitted unique experimental simulation of this system.
The coupled-wall test specimen simulated the bottom three stories of a ten-story building in a region of high seismicity designed with typical geometry and reinforcement.
[-] The following 14 users Like TAFATNEB's post:14 users Like TAFATNEB's post
  • malc, rezart, ibg0203, vardan, ssobhan, PinkPant, Mohammad6299, ruaumoko, zrilek, viet2010, Albert, ting tsai huang, Dell_Brett, moh_towhid
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,937 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  Seismic Performance Assessment and Probabilistic Repair Cost Analysis of Precast Conc TAFATNEB 0 1,573 07-03-2015, 10:30 PM
  SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE TAFATNEB 0 1,878 03-27-2015, 03:16 PM
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,786 03-27-2015, 11:44 AM
  Mechanical behavior of RC walls under seismic activity strenghtened with CFRP TAFATNEB 1 1,847 02-09-2015, 04:42 PM
Last Post: Veggeta
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,906 02-09-2015, 07:24 AM
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 1,800 10-08-2014, 02:00 PM
