Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRU
04-12-2014, 02:40 PM
A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRUCTURES
Author: Fabio F. Taucer Research Assistant Enrico Spacone Doctoral Student and Filip C. Filippou Associate Professor Department of Civil Engineering | Size: 2.6 MB | Format: PDF | Quality: Unspecified | Publisher: Report No. UCB/EERC-91/17 Earthquake Engineering Research Center College of Engineering University of California, Berkeley | Year: 1991 | pages: 140
[Image: 44074061501562670497.png]
This study proposes a reliable and computationally efficient beam-column finite element model for the analysis of reinforced concrete members under cyclic loading conditions that induce biaxial bending and axial force. The element is discretized into longitudinal steel and concrete fibers such that the section force-deformation relation is derived by integration of the stress-strain relation of the fibers. At present the nonlinear behavior of the element derives entirely from the nonlinear stress-strain relation of the steel and concrete fibers.
The proposed beam-column element is based on the assumption that deformations are small and that plane sections remain plane during the loading history. The formulation of the
element is based on the mixed method: the description of the force distribution within the element by interpolation functions that satisfy equilibrium is the starting point of the
formulation. Based on the concepts of the mixed method it is shown that the selection of flexibility dependent shape functions for the deformation field of the element results in
considerable simplification of the final equations. With this particular selection of deformation shape functions the general mixed method reduces to the special case of the
flexibility method. The mixed method formalism is, nonetheless, very useful in understanding the proposed procedure for the element state determination. A special flexibility based state determination algorithm is proposed for the computation of the stiffness matrix and resisting forces of the beam-column element. The proposed nonlinear algorithm for the element state determination is general and can be used with any nonlinear section force-deformation relation. The procedure involves an element iteration scheme that converges to a state that satisfies the material constitutive relations within the specified tolerance. During the element iterations the equilibrium and the compatibility of the element are always satisfied in a strict sense by the assumed force and deformation interpolation functions. The proposed method proved to be computationally stable and robust, while being able to describe the complex hysteretic behavior of reinforced concrete members, such as strain hardening, "pinching" and softening under cyclic nodal and element loads.
  • vardan, rezart, giga, ting tsai huang, malc, ykhackhack, blaze, Rodmo376
  Non-linear analysis of a collapsed reinforced concrete chimney mybest 1 3,863 11-06-2020, 08:17 AM
  The Seismic Analysis of Statically Designed Tall Reinforced Concrete Buildings Using bridgeengineer 0 2,960 04-20-2016, 09:31 AM
Last Post: bridgeengineer
  SEISMIC PERFORMANCE ASSESSMENT OF REINFORCED CONCRETE BUILDINGS WITH PRECAST CONCRETE TAFATNEB 0 1,886 03-27-2015, 03:16 PM
  Inelastic seismic response of precast concrete large panel coupled shear wall sys TAFATNEB 0 1,805 03-27-2015, 11:44 AM
  Finite Element Analysis of the Seismic Behavior of Guyed Masts TAFATNEB 0 1,708 12-26-2014, 09:54 PM
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,784 09-02-2014, 08:10 AM
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 1,762 08-31-2014, 07:45 AM
