Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Nonlinear Dynamic Analysis of a Structure with a Friction-Based Seismic Base Isolati
04-02-2014, 01:13 PM (This post was last modified: 04-05-2014, 10:40 AM by Dell_Brett.)
Nonlinear Dynamic Analysis of a Structure with a Friction-Based Seismic Base Isolation System
Author: H.M.R. Suy TU/e Report No. DCT 2005-25 TNO Report No. 2005-CI-R0028 | Size: 7.2 MB | Format: PDF | Quality: Unspecified | Publisher: Eindhoven University of Technology | Year: 2005 | pages: 131
[Image: 57380710770633272533.png]
Earthquakes constitute a substantial form of excitation of structures in terms of their large potential to cause structural damage. Therefore, in earthquake-prone regions, the seismic resistance of structures is carefully studied during the design phase. In regions where seismicity is insigni cant,
the conventional design approach aims at the design of structural members in such a way that static (gravitational) and dynamic loads (such as wind load) are withstood elastically. However, if this design approach was to be followed in cases where seismic excitation had to be taken into account, this might lead to economically unacceptable design solutions. For example, the designmight result in very large and, hence, expensive structural members. For that reason, two alternativedesign concepts are often chosen [ECS, 2001].In the rst design concept, plastic deformation during excitation is allowed in special parts ofthe structure, often called plastic hinges, while the rest of the structure remains in its elasticrange. These plastic hinges are designed for high ductility, in order to ensure global stability of the structure [ECS, 2001]. Because the energy dissipation through plastic deformation is muchlarger than if the structure would remain elastic, the load-capacity of the structural members can
be signi cantly reduced, resulting in a more economical design.
  • vardan, rezart, Mohammad6299, ting tsai huang, ali akbar, malc, blaze, slowet, Dell_Brett
  Dynamic Soil-Structure-Soil-Interaction Analysis of Structures in Dense Urban Environ TAFATNEB 0 1,637 07-03-2015, 09:25 PM
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 1,922 02-09-2015, 07:24 AM
  CONTINUUM DAMAGE MODEL FOR NONLINEAR ANALYSIS OF MASONRY STRUCTURES TAFATNEB 0 1,818 11-15-2014, 01:51 PM
  NONLINEAR ANALYSIS OF MULTISTORY STRUCTURES USING NONLIN TAFATNEB 0 1,930 10-06-2014, 10:12 AM
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 1,754 08-31-2014, 07:45 AM
  Cyclic Properties of Sand: Dynamic Behaviour for Seismic Applications TAFATNEB 0 1,674 08-12-2014, 01:52 PM
  Nonlinear Winkler-based shallow foundation model for performance assessment of seismi TAFATNEB 0 1,775 05-09-2014, 06:00 PM
