Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis EFFICIENT FINITE ELEMENT MODELING OF REINFORCED CONCRETE COLUMNS CONFINED WITH FIBER
03-31-2014, 10:33 PM
EFFICIENT FINITE ELEMENT MODELING OF REINFORCED CONCRETE COLUMNS CONFINED WITH FIBER REINFORCED POLYMERS
Author: by Dan Hu Southwest Jiaotong University, China, | Size: 2.1 MB | Format: PDF | Quality: Unspecified | Year: 2012 | pages: 126
[Image: 82201478000359631792.png]
Fiber reinforced polymer (FRP) composites have found extensive applications in the field of Civil Engineering due to their advantageous properties such as high strength-to-weight ratio and high corrosion resistance. This study presents a simple and efficient frame finite element (FE) able to accurately estimate the load-carrying capacity and ductility of reinforced concrete (RC) circular columns confined with externally bonded fiber reinforced polymer (FRP) plates and/or sheets. The proposed FE considers distributed plasticity with fiber-discretization of the cross- sections in the context of a force-based (FB) formulation. The element is able to model collapse due to concrete crushing, reinforcement steel yielding, and FRP rupture.
The frame FE developed in this study is used to predict the load-carrying capacity of FRP- confined RC columns subjected to both concentric and eccentric axial loading. Numerical simulations and experimental results are compared based on experimental tests available in the literature and published by different authors. The numerically simulated responses agree well with the corresponding experiment results. The outstanding features of this FE include computational efficiency, accuracy and ease of use. Therefore, the proposed FE is suitable for efficient and accurate modeling and analysis of RC columns confined with externally retrofitted
FRP plates/sheets as for parametric studies requiring numerous FE analyses.
[-] The following 17 users Like TAFATNEB's post:17 users Like TAFATNEB's post
  • rezart, AloneGalaxy, malc, Mohammad6299, vardan, PinkPant, cace-01, blaze, ssobhan, ykhackhack, Batman07, oanm2000, ting tsai huang, zrilek, Dell_Brett, faros3000, simanta
  Finite Element Analysis of the Seismic Behavior of Guyed Masts TAFATNEB 0 1,648 12-26-2014, 09:54 PM
  PREDICTION OF FLOOR VIBRATION RESPONSE USING THE FINITE ELEMENT METHOD TAFATNEB 0 1,595 08-08-2014, 02:11 PM
  SHEAR STREN GTH OF CIRCULAR REINFORCED CONCRETE COLUMNS TAFATNEB 0 1,558 06-01-2014, 03:41 PM
  PUNCHING SHEAR STRENGTH AND DE FORMATION CAPACITY OF FIBER REINFORCED CONCRETE SLAB-C TAFATNEB 0 1,578 06-01-2014, 03:30 PM
  Seismic Performance, Modeling, and Failure Assessment of Reinforced Concrete Shear Wa TAFATNEB 0 1,606 05-09-2014, 04:00 PM
  A FIBER BEAM-COLUMN ELEMENT FOR SEISMIC RESPONSE ANALYSIS OF REINFORCED CONCRETE STRU TAFATNEB 0 1,583 04-12-2014, 02:40 PM
  DRIFT CAPACITY OF REINFORCED CONCRETE COLUMNS SUBJECTED TO DISPLACEMENT REVERSALS TAFATNEB 0 1,685 10-04-2013, 07:04 PM
