Civil Engineering Association eBooks Journals, Papers and Presentations III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS
03-31-2014, 10:11 PM
Author: Christina Claeson | Size: 334 KB | Format: PDF | Quality: Unspecified | Publisher: Research Assistant, M.Sc. Division of Concrete Structures Chalmers University of Technology S-412 96 Göteborg, Sweden | pages: 20
[Image: 65850787561705141854.png]
Finite element analyses of confined columns are presented.
Based on a confinement dependent uniaxial concrete model,
the importance of the yield strengths of the stirrups and the
longitudinal reinforcement bars, the spacing of the stirrups,
and the configuration of the cross-section, in combination
with different load eccentricities are evaluated. It was found
that the spacing of the stirrups and the reinforcement
configuration are of the greatest importance for the post-peak
behavior. To achieve ductile structural behavior of highstrength
concrete columns, a higher value of the volumetric
stirrup ratio is required. However, it was found that, even for
concretes currently accepted by the code, a higher ratio than
that corresponding to the required maximum spacing of 15f is
needed to obtain the same ductility as a concrete of grade
K40.
  • Dell_Brett, rezart, AloneGalaxy, malc, levanduy, Mohammad6299, vardan, cace-01, blaze, techno, ting tsai huang, zrilek, mowafi3m
  ConPrimer-2 Finite Element emmi 0 5,004 03-27-2015, 12:59 AM
Last Post: emmi
  DESIGN OF REINFORCED CONCRETE COLUMNS (EUROCODE 2) odiclas 0 4,506 08-26-2014, 03:02 AM
Last Post: odiclas
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 5,012 03-31-2014, 10:46 PM
  FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 4,970 03-31-2014, 10:22 PM
  FINITE ELEMENT ANALYSIS OF BASE ISOLATED BUILDINGS SUBJECTED TO EARTHQUAKE LOADS TAFATNEB 1 5,713 11-20-2013, 07:25 AM
  SEISMIC RESPONSE ANALYSIS OF ANCIENT COLUMNS TAFATNEB 0 3,428 09-03-2013, 07:16 AM
  PEFORMANCE OF EXISTING REINFORCED CONCRETE COLUMNS UNDER BIDIRECTIONAL SHEAR AND AXIA TAFATNEB 0 3,992 08-27-2013, 08:45 AM
