Civil Engineering Association eBooks Structural Books Concrete Static and dynamic analysis of a reinforced concrete flat slab frame building for pro
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
03-16-2014, 05:11 PM
Static and dynamic analysis of a reinforced concrete flat slab frame building for progressive collapse
Author: Seweryn Kokot, Armelle Anthoine, Paolo Negro, George Solomos | Size: 3.9 MB | Format: PDF | Quality: Original preprint | Publisher: European Commission, Joint Research Centre, Institute for the Protection and Security of the Citizen | Year: 2010 | pages: 94 | ISBN: N.A. - PUBSY JRC 62663 - 2010
[Image: 64379554677032027784.png]
European Commission
Joint Research Centre – Institute for the Protection and Security of the Citizen
Title: Static and dynamic analysis of a reinforced concrete flat slab frame building for progressive collapse
Author(s): Seweryn Kokot, Armelle Anthoine, Paolo Negro, George Solomos
Luxembourg: Publications Office of the European Union
2010 – 94 pp. – 21.0 x 29.7 cm
Abstract
The problem of the progressive collapse of a building has been addressed using a reinforced concrete
flat slab frame. This structure was tested in the past at the ELSA laboratory to evaluate safety margins
against collapse. Static linear and nonlinear analyses of the building under column removals had first
been performed and then, in the experiment, columns had been successively removed, slowly
demolished with a crunching machine. The experiment showed that the structure survived the
demolition of two central columns, and also that structural testing against progressive collapse can be
very challenging.
Extending the scope, the dynamic nature of the loading has been considered in this report since
buildings can be exposed to fast dynamic abnormal events, such as explosions or impacts, which may
destroy abruptly load bearing elements. Thus, this study tries to answer the question of what would
have happened to this building if the columns had been destroyed dynamically. For the same
structural model dynamic linear and nonlinear analyses have been performed employing the finite
element computational framework of the SAP2000 code. Alternately, three columns, a central and two
corner ones, have been instantaneously removed and the structural response of the frame calculated.
Maximum values of bending moments and forces at critical sections are reported and compared to
those of the static analyses. Time histories of deflections of nodes above missing columns are
determined, and several ratios of response parameters resulting from the different analyses are
produced for comparison purposes. All approaches predict no mechanism which might lead to
progressive collapse, even though several hinges are formed. Advantages of the use of static or
dynamic, linear or nonlinear analyses are discussed.
[-] The following 30 users Like gulilero's post:30 users Like gulilero's post
  • Mohammad6299, vardan, rezart, 3fan, Dell_Brett, malc, ting tsai huang, viet2010, ibg0203, cace-01, ykhackhack, knrsa, subin91, mgdario, jfjdm, jcoronellr, cristi, avge, draluka, Quantumm, hignacio43, yutt, zrilek, Visitante, ruaumoko, chenamoy, K.Lee, ssobhan, igor1234, TurboXUser
 gulilero
Italy
User ID: 14057
Threads: 113
Given Likes: 6732
05-18-2016, 01:31 AM
Not the Report but a paper with a summary of the findings
[-] The following 8 users Like gulilero's post:8 users Like gulilero's post
  • K.Lee, Dell_Brett, zrilek, blaze, subin91, malc, Wijono, pedzaquino
 subin91
Semi Senior Member
User ID: 2232
Threads: 35
Likes: 2,192 in 111 posts
Given Likes: 4684
05-18-2016, 06:24 AM
NEW Link From Post#1
[-] The following 12 users Like subin91's post:12 users Like subin91's post
  • KhaLed-S.E, ykhackhack, simanta, PinkPant, malee, Jackass, gulilero, tomtumx, slowet, TurboXUser, pedzaquino, Aransam
  Reinforced Concrete Structures: Analysis and Design ska51 6 5,925 11-07-2022, 11:56 AM
Last Post: haniakkari
  Preliminary Design of a 20-story Reinforced Concrete Building wafiullah 1 2,925 02-28-2022, 11:36 AM
Last Post: bigone
  Design of prestressed Concrete flat slabs tuanpecc1 5 4,949 12-09-2021, 07:59 AM
Last Post: Gabemzaman
  Ciria - Guide to the Reinforced Construction of Reinforced Concrete in the Arabian Pe Jackass 1 3,719 02-23-2019, 11:34 AM
Last Post: Icivilea
  Behaviour Of Reinforced Concrete Flat Slabs mowafi3m 3 3,915 07-19-2018, 12:38 PM
Last Post: febo927
  Guide to the design and construction of reinforced concrete flat slabs gulilero 3 3,489 04-14-2018, 09:08 AM
Last Post: gianniorlati
  Manual for the design of reinforced concrete building structure 2002 Grunf 11 7,888 11-11-2017, 11:01 PM
Last Post: monter
