Civil Engineering Association Software Software Product Csi Products SAP2000 SAP2000 V16
SAP2000 V16
 struceng
Russian Federation
User ID: 258
Threads: 268
Likes: 10,197 in 602 posts
Given Likes: 741
09-13-2013, 07:40 AM (This post was last modified: 05-15-2024, 07:08 AM by poolmand.)
CSI SAP2000 v16.0.0
[Image: 09006279614267163825.jpg]
SAP2000 V16 Enhancements
Significant enhancements included in SAP2000 v16.0.0, besides bug fixes:
Improved graphics performance
Display of multiple grid systems at the same time
New steel frame design code AISC 360-10
New steel frame design code NTC 2008
New concrete frame design code ACI 318-11
New concrete frame design code NTC 2008
New concrete frame design code NZS 3101-06
New concrete frame design code RCDF 2004
New concrete frame design code Hong Kong CP 2013
Enhanced beam-column capacity check for concrete frame design using Eurocode 2-2004
Stiffness modifiers from the AISC 360 steel frame design direct analysis method are now available in the database table for assigned frame property modifiers
New wind, seismic, and response-spectrum lateral loads for code IBC 2012
New wind lateral loads for code AS/NZS 1170.2-2011
New wind, seismic, and response-spectrum lateral loads for code NTC 2008
New wind, seismic, and response-spectrum lateral loads for codes TSC 2007 and TS 498-97
New response-spectrum lateral loads code AASHTO 2012
New assignment to control area loads transferred to frames
New hybrid U-girder frame section property
New built-in ASTM bridge steel materials
Chinese concrete material and design updated to use characteristic strength rather than grade
New link property for modeling triple-pendulum bearings
External tendons can now be modeled under user control
Plotting of tendon loads, losses, and axial-force response has been enhanced
Ground displacement loading now applies to single-joint links, including distributed spring supports, as well as to springs and restraints
Multiple mass sources can be defined for modeling alternative dynamic behavior
The undeformed shape can now be viewed for various stages of staged construction load case without running the analysis
Response output for staged-construction load cases now is labeled with the stage and step within the stage
Shear stress, von Mises stress, and principal stress response is now available for certain frame sections
Shell stresses can now be displayed normalized by material strength
Bearing pressure on shells from area springs can now be displayed
Display of frame-design D/C ratios can be limited by a specified threshold value
Verification suites are now provided for steel and concrete frame design by most codes
New Open API functions to define section-cuts
New Open API functions to define external load cases for frame results
New Open API functions to get detailed steel frame design results for certain codes
Customizable keyboard shortcuts for menu commands
Support for the import and export of files using the IFC 4 format
Licensing will now support web-activation and virtual servers
Simplified installation using the CSI Installation Wizard
Other minor enhancements
[Image: homepage.png]
[-] The following 66 users Like struceng's post:66 users Like struceng's post
  • giga, blaze, aslam, Andrew seah, drewpt, LiviuM, chandra1234567, joker™, milvio, devilmaycry, maad59, axcel, Rodmo376, rezart, tomtumx, warbeast, simanta, zrilek, learner20, ali akbar, eng_ismail, oanm2000, ebzr, er.shyams, ivanveliki, mgdario, mecheil.edwar, knrsa, KhaLed-S.E, chairatpk, bigone, amareen2000, chottabhai, miquan, pezhmankhan, TAFATNEB, cace-01, Dell_Brett, Visitante, coxxxyboy, XXXX123, SCREAM7890, faros3000, malc, ykhackhack, herea, jcbv, avscorreia, RyanRS, yutt, Padrino, hignacio43, caraiane, mowafi3m, eRw1n, maijuji, araza023, harsono, chenamoy, Batman07, hamarat007, PinkPant, lisine, kkding, pram, jonny78
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
09-14-2013, 11:47 AM
365 days trial licence
[-] The following 53 users Like aslam's post:53 users Like aslam's post
  • pezhmankhan, rezart, zrilek, KhaLed-S.E, milvio, cace-01, zipatton, Dell_Brett, shapoor5657, l_namali, seriousboy, Visitante, oanm2000, tomtumx, aema, ssobhan, XXXX123, giga, SCREAM7890, joker™, malc, ykhackhack, ArissB, bigone, herea, ali akbar, jcbv, avscorreia, drewpt, Andrew seah, RyanRS, Padrino, hignacio43, Williams, caraiane, mowafi3m, eng_ismail, eRw1n, maijuji, araza023, nickycruz, Batman07, pedroxl66, PinkPant, lisine, kkding, wa_sin_29, narendra, jonny78, rottweiler, anfaga, slowet, shark
Likes: 12,073 in 1,233 posts
09-14-2013, 12:03 PM
[-] The following 55 users Like pezhmankhan's post:55 users Like pezhmankhan's post
  • rezart, zrilek, TAFATNEB, KhaLed-S.E, stosto6666, cace-01, learner20, Dell_Brett, mecheil.edwar, shapoor5657, devilmaycry, Songoku, Petrit, tomtumx, mahyarov, coxxxyboy, fred2010, hatkam, XXXX123, zipatton, giga, SCREAM7890, slowet, faros3000, ykhackhack, bigone, herea, ali akbar, haze, Rainbow, jcbv, avscorreia, drewpt, RyanRS, blaze, simanta, ivanveliki, Padrino, mgdario, Williams, eliseo.as, eRw1n, araza023, mowafi3m, Rami11, harsono, Batman07, hamarat007, PinkPant, gampang_ingat, amirdana, sructme, jonny78, narendra, shark
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42472
09-15-2013, 07:19 AM (This post was last modified: 11-13-2013, 03:47 AM by BennyP.)
(Grabbed from other site - the same originally posted in LV forum)
[-] The following 23 users Like Dell_Brett's post:23 users Like Dell_Brett's post
  • malc, jcbv, avscorreia, rezart, zrilek, drewpt, rendel_©, oanm2000, milvio, ivanveliki, TAFATNEB, Williams, mowafi3m, panchotevi, bigone, cristi, eRw1n, Batman07, hamarat007, PinkPant, jonny78, oreslaw, narendra
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Given Likes: 2168
10-03-2013, 02:15 AM
SAP2000 V16.0.1
SAP2000 V16.0.0 and V16.0.1 Enhancements
Significant enhancements included in SAP2000 v16.0.0 and v16.0.1, besides bug fixes:
[-] The following 28 users Like aslam's post:28 users Like aslam's post
  • rezart, bprm, yamacdere, ssobhan, amareen2000, Andrew seah, joker™, LiviuM, blaze, SCREAM7890, milvio, zrilek, ashcivilea, faros3000, raja, MOSS2000, Williams, georgegps, amirdana, pram, learner20, bigone, jcbv, oanm2000, Visitante, jonny78, mowafi3m, nowanda
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Given Likes: 2168
10-29-2013, 07:03 AM
SAP2000 V16.0.2 (install only)
[-] The following 18 users Like aslam's post:18 users Like aslam's post
  • milvio, learner20, jcbv, simanta, Dell_Brett, zrilek, faros3000, Williams, malc, stosto6666, bigone, knrsa, Visitante, nickycruz, jonny78, mowafi3m, nowanda, shark
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
11-02-2013, 08:07 PM
The key generator here
works for this last version of SAP2000 too.
[-] The following 16 users Like BennyP's post:16 users Like BennyP's post
  • zrilek, ykhackhack, seriousboy, faros3000, Williams, malc, Dell_Brett, mowafi3m, chenamoy, MOSS2000, bigone, oanm2000, jcbv, pezhmankhan, nickycruz, jonny78
11-04-2013, 06:19 AM
CSi License Generator 2013+Help
[Image: 45382262065416287025.png]
[-] The following 20 users Like pezhmankhan's post:20 users Like pezhmankhan's post
  • malc, bigone, MOSS2000, Dell_Brett, oanm2000, milvio, Visitante, Williams, avge, vladmorigi, ebzr, PinkPant, jonny78, melekeen, narendra, mowafi3m, nowanda, oreslaw, anfaga, harsono
11-30-2013, 06:37 PM
CSI SAP2000 V 16.02
[Image: 37460490060662224373.jpeg]
SAP2000 is general-purpose civil-engineering software ideal for the analysis and design of any type of structural system. Basic and advanced systems, ranging from 2D to 3D, of simple geometry to complex, may be modeled, analyzed, designed, and optimized using a practical and intuitive object-based modeling environment that simplifies and streamlines the engineering process.
The SAPFire Analysis Engine integral to SAP2000 drives a sophisticated finite-element analysis procedure. An additional suite of advanced analysis features are available to users engaging state-of-the-art practice with nonlinear and dynamic consideration. Created by engineers for effective engineering, SAP2000 is the ideal software tool for users of any experience level, designing any structural system.
Integrated modeling templates, code-based loading assignments, advanced analysis options, design-optimization procedures, and customizable output reports all coordinate across a powerful platform to make SAP2000 especially useful for practicing professionals.
Version: 16.0.2
Home: csiamerica . com
Interface: english
OS: Windows XP / Vista / Seven
[-] The following 28 users Like TAFATNEB's post:28 users Like TAFATNEB's post
  • kkding, malc, chottabhai, chenamoy, SCREAM7890, ykhackhack, oreslaw, slowet, ibmarin, highcivil, harsono, MOSS2000, simanta, Visitante, mgdario, anfaga, mecheil.edwar, bigone, hamarat007, wa_sin_29, paitaconst, ssobhan, giga, rezart, cace-01, oanm2000, cve_jule, aleph177
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
01-21-2014, 06:23 AM (This post was last modified: 01-21-2014, 06:30 AM by bigone.)
SAP2000 v16.0.2
direct link
Keygen
[-] The following 31 users Like bigone's post:31 users Like bigone's post
  • ssobhan, stosto6666, Andrew seah, blaze, giga, malc, englandboy, Dell_Brett, rezart, Mohammad6299, cace-01, shaker, oanm2000, simanta, Petrit, Quantumm, faros3000, ykhackhack, cve_jule, manzoor_quadri, chottabhai, TAFATNEB, user, Rami11, raymelito, spanac, ferbasilio, Wijono, pram, psk62, toa011
Pages (3): 1 2 3 Next »
