Civil Engineering Association eBooks Journals, Papers and Presentations Evaluation of parameters affected on the blast induced ground vibration (BIGV) by usi
08-31-2013, 10:09 PM
Evaluation of parameters affected on the blast induced ground vibration (BIGV) by using relation diagram method (RDM)
Author: Birol Elevli and Ercan Arpaz | Size: MB | Format: PDF | Quality: Unspecified | Publisher: University, Industrial Engineering Dpt, Samsun, Turkey
[Image: 02261172185683111015.png]
This paper presents the application of relation diagram method (RDM) to determine contribution of the parameters affected
on the blast induced ground vibration. There are two types of parameters: controllable and uncontrollable parameters. The study focused on controllable parameters. The more effective parameters for ground vibration at the point of interest are ground vibration in the point of blast (PPV in-blast) and geological structures. The more effective parameters for the ground vibration at the point of blast are explosive amount per delay, burden and stemming. If desired fragmentation is obtained from the blast, then geological structures should be modified by creating artificial discontinuities. If one desires to reduce the level of vibration in the point of blast,
then the following parameters should be modified ; explosive amount per delay, burden, stemming, and hole diameter.
  • malc, vardan, sodapas, blaze, Shahin, gulilero, kowheng, Dell_Brett
  PREDICTION OF GROUND VIBRATION FROM RAILWAYS TAFATNEB 0 4,175 08-12-2014, 02:16 PM
  FOOTFALL INDUCED VIBRATION IN LONGSPAN COMPOSITE STEEL BEAMS USED IN TWO PROJECTS AT TAFATNEB 1 4,375 08-08-2014, 05:35 PM
Last Post: r3be1
  Estimation of mean annual precipitation as affected by elevation using multivariate g arshiakh 0 3,778 04-08-2013, 06:15 PM
Last Post: arshiakh
  TTM Ground Anchors, Geotechnical and ground anchor system ir_71 0 4,798 06-24-2011, 06:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 5,024 09-27-2010, 02:38 PM
Last Post: giguni
