Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Uniaxial and Triaxial Behavior of high strength concrete with and without steel fibe
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
11-27-2012, 10:32 PM
Uniaxial and Triaxial Behavior of high strength concrete with and without steel fibers
Author: Xiaobin Lu | Size: 5.08 MB | Format: PDF | Quality: Scanner | Publisher: Xiaobin Lu | Year: 2005 | pages: 207
his study first presents an extensive experimental research program on the true uniaxial and triaxial compression behavior for both high strength concrete (HSC) and steel fiber reinforced high strength concrete (SFHSC). The experimental study mainly focuses on the octahedral shear stress ~ strain relationship of those two types of concrete, which is adopted as the basis to develop a new incremental constitutive model. Emphasis is also put on the investigation of the variation of tangent Poisson's ratio under not only uniaxial but also triaxial stress conditions. The effect of cyclic loading on this parameter is also addressed.
[-] The following 3 users Like asim99's post:3 users Like asim99's post
  • kowheng, malc, Dell_Brett
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,774 09-02-2014, 08:10 AM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,653 05-30-2014, 02:05 PM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,687 04-19-2014, 08:58 AM
  Analysis and modelling of the seismic behaviour of high ductility steel-concrete co TAFATNEB 0 1,738 04-02-2014, 01:31 PM
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN - Msc Thesis asim99 1 2,174 11-17-2013, 08:49 AM
Last Post: st77bel
  Analysis and modelling of the seismic behaviour of high ductility steel-concrete comp TAFATNEB 0 1,652 09-03-2013, 07:46 AM
  Improving The Behavior of Special Concentrically Brace Frame w/ Cast Steel Inserts asim99 1 1,949 02-27-2013, 11:15 PM
Last Post: LiviuM
