Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Seismic Behavior of Circular Reinforced Concrete Bridge Columns under Combined Loadin
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
10-27-2012, 02:21 PM
Seismic Behavior of Circular Reinforced Concrete Bridge Columns under Combined Loading Including Torsion
Author: Shanmugam, Suriya Prakash | Size: 56.97 MB | Format: PDF | Quality: Unspecified | Publisher: University of Nevada | Year: 2009 | pages: 338
[Image: 11635275134055040946.png]
Reinforced concrete (RC) columns of skewed and curved bridges with unequal spans and column heights can be subjected to combined loading including axial, flexure, shear, and torsion loads during earthquakes. The combination of axial loads, shear force, and flexural and torsional moments can result in complex failure modes of RC bridge columns. This study carried out experimental and analytical studies to investigate the seismic performance of circular RC columns under combined loading including torsion. The main variables considered here were (i) the ratio of torsion-to-bending moment (T/M), (ii) the ratio of bending moment-to-shear (M/V) or shear span (H/D), and (iii) the level of detailing for high and moderate seismicity (high or low spiral ratio). In particular, the effects of the spiral reinforcement ratio and shear span on strength and ductility of circular RC columns under combined loading were addressed. In addition, the effects of torsional loading on the bending moment-curvature, ductility, and energy dissipation characteristics were also considered. The analytical investigation examined the development of existing models for flexure and pure torsion. Interaction diagrams between bending, shear and torsional loads were established from a semi-empirical approach. A damage-based design approach for circular RC columns under combined loads was proposed by decoupling damage index models for flexure and torsion. Experimental and analytical results showed that the progression of damage was amplified by an increase in torsional moment. An increase in the transverse spiral reinforcement ratio delayed the progression of damage and changed the torsional-dominated behavior to flexural-dominated behavior under combined flexural and torsional moments.
  • blaze, cace-01, kowheng, malc
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 2,886 06-28-2024, 02:32 PM
  Seismic Design of Reinforced Concrete Buildings cace-01 10 9,186 05-25-2024, 10:30 AM
  Seismic Behavior and Design Guidelines for Steel Frame Structures with Added Viscoela david-smith 3 3,786 12-20-2022, 07:30 PM
Last Post: bridgeengineer
  Seismic Design Aids for Nonlinear Analysis of Reinforced Concrete Structures pezhmankhan 11 10,106 05-05-2019, 12:17 AM
  Dynamic Behavior of Concrete and Seismic Engineering abudabeeja 10 6,928 07-20-2018, 04:04 AM
Last Post: axcel
  Seismic Design of Reinforced Concrete structure (Notes) david-smith 1 3,025 07-10-2018, 05:22 AM
Last Post: jeevaniitn
  Nonlinear Seismic Analysis and Design of Reinforced Concrete Buildings lisine 7 5,626 07-06-2018, 09:24 PM
