Civil Engineering Association Software Software Product Bentley Products Bentley StormCAD V8i 08.11.
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
07-12-2010, 03:58 PM
Bentley StormCAD V8i 08.11.02.35 (Trial)
StormCAD provides comprehensive modeling for the design and analysis of storm sewer systems. StormCAD provides calculations for catchment runoff, gutters, inlets, junctions, pipe networks, and outfalls, and its intuitive interface makes the design and analysis of storm sewer systems easier than ever. Available for AutoCAD, or as a stand-alone product, StormCAD includes automated constraint-based design; scenario and data management and reporting capabilities.
Trial
[Image: 82736256718483465064.gif]
[-] The following 5 users Like BennyP's post:5 users Like BennyP's post
  • Dell_Brett, gacella, erbalaji, snakes, ecligg01
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
12-02-2011, 04:37 AM
Bentley StormCAD V8i United Kingdom
(Version: 08.11.02.75 Date: 11/7/2011) 14.98 MB
(Version: 08.11.02.75 Date: 11/7/2011) 256.66 MB
  • Dell_Brett, mahyarov, malc, surajdas
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
10-24-2012, 08:56 AM
Bentley StormCAD V8i (SELECTseries 2) 08.11.02.75
[Image: 84589542444792171210.gif]
StormCAD provides comprehensive modeling for the design and analysis of storm sewer systems. StormCAD is FEMA-approved and provides calculations for catchment runoff, gutters, inlets, junctions, pipe networks, and outfalls, and its intuitive interface makes the design and analysis of storm sewer systems easier than ever.
StormCAD includes automated constraint-based design, scenario and data management, and reporting capabilities.
[-] The following 10 users Like BennyP's post:10 users Like BennyP's post
  • alejandrocv, joker™, malc, seriousboy, blaze, oanm2000, ykhackhack, Nilupa, snakes, surajdas
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
10-24-2012, 01:14 PM
Mirror
No limits to creativity
[-] The following 4 users Like joker™'s post:4 users Like joker™'s post
  • oanm2000, ykhackhack, cace-01, Nilupa
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
01-18-2013, 09:30 AM
Only install files
  • joker™, ska51, snakes, malc
Away  joker™
User ID: 10925
Threads: 92
Given Likes: 2426
01-22-2013, 03:10 PM
Patch for Bentley StormCAD V8i Version: 08.11.03.77
[-] The following 6 users Like joker™'s post:6 users Like joker™'s post
  • ska51, snakes, andres_emen, cesar, malc, Dell_Brett
 rami1976
User ID: 34597
Threads: 341
Likes: 9,523 in 1,137 posts
Given Likes: 1387
12-16-2015, 06:47 AM
Bentley StormCAD V8i SS5 08.11.05.58
[Image: 70334299957423335165.jpg]
[Image: 81551810172232644639.jpg]
[Image: 17888005270813951619.jpg]
[Image: 47926294422482356130.jpg]
[Image: 06621030100551975940.jpg]
Bentley StormCAD is software for integrated design and analysis of storm sewer systems. The intuitive interface of the program makes it easier than ever the design and analysis of systems of stormwater runoff from the street to the water outlet opening. Bentley StormCAD calculates volume flow, the intensity of the input stream, storm water and flow in the pipeline.
Bentley StormCAD is a turnkey solution that allows you to use it independently, or in AutoCAD. Regardless of platform, software Bentley StormCAD contains a single set of data files for the appropriate model for interoperability with each platform.
Standalone interface provides easy to use layout tools model, support the background of complicated structure, conversion utilities from CAD, GIS and databases, and unlimited levels of undo and redo operations layout. In addition, AutoCAD users can add AutoCAD integration features to create, build, and charting patterns with high precision in an environment that has become familiar to them.
Bentley StormCAD defines interception of the flow of the receiving water collector system and directs the flow of the bypass channel to the selected endpoints. Water intakes can be calculated by the method of the Federal Highway Administration US (FHWA) HEC-22, and as the water intakes can be selected lattice, curbs, manholes, ditches, and combinations thereof. Engineers can use a variety of methods for calculating the pressure loss, including methods HEC-22 Energy and AASHTO.
Bentley StormCAD used to determine the subcritical, critical and supercritical conditions using standard reliable Slowly Changing incremental algorithms. Bentley StormCAD expects friction loss of flow using Manning formulas, Cutters, Darcy-Weisbach and Hazen-Williams, and also allows you to select segments of the pipe round, square, arched or elliptical, and irregular sections of sewer, trapezoidal or triangular shape.
Bentley StormCAD uses a rational method of calculating the peak flood flow when designing the collector storm sewer. Instead, flow, calculated rational way, Bentley StormCAD also allows direct input of known flow rates for supply intakes. You can enter or import data about time concentration of the catchment area, or by specifying the minimum allowable time of concentration to avoid exceeding the maximum flow volume of small receiving waters
[-] The following 3 users Like rami1976's post:3 users Like rami1976's post
  • bridgeengineer, Dell_Brett, oanm2000
