Civil Engineering Association Software Software Product Bentley Products RAM Elements V8i (SELECTseries 4) 13.0.0.22 1000 days trial
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
09-25-2012, 06:14 AM
[Image: 90563532738542488953.gif]
[Image: 07204513924290406152.gif]
[Image: 42034389615216884070.gif]
[Image: 75714977922312442249.gif]
This program provides unequaled flexibility for the design and analysis of different types of 2D or 3D structures containing linear members and shell elements.
The types of analysis available are: First order (Linear Analysis), Second order (P-Delta Analysis) and Dynamic (Seismic Analysis).
In addition, RAM Elements is also capable of designing hot-rolled or cold-formed steel members, wood (sawn lumber and glulam) and reinforced concrete members using the AISC 360-05 ASD, AISC 360-05 LRFD, AISC 360-10 ASD, AISC 360-10 LRFD, AISC 341-05, AISC 341-10, BS 5950-00, AISI 01 ASD, AISI 01 LRFD, AS 4100-98, CSA S16-09, NDS 05 ASD, NDS 05 LRFD, ACI 318-99, ACI 318-05 and BS8110-97 codes respectively. The program includes special modules for designing spread footings, combined footings, reinforced concrete columns, retaining walls, concrete walls, tilt-up walls, masonry walls, continuous beams and trusses.
[Image: comments.png]
[-] The following 51 users Like BennyP's post:51 users Like BennyP's post
  • blaze, malc, Dell_Brett, mahyarov, seriousboy, ykhackhack, cace-01, malee, joker™, isurya, wesam_19701970, pezhmankhan, rendel_©, coxxxyboy, Milkshake, oanm2000, odiclas, maad59, panchotevi, kowheng, Andrew seah, JOGAR71, fretts08, mgdario, jjmtz, ricarma, araza023, cybermad, cordoba123, zrilek, Diquan, quartinus, er.shyams, olgabehe, constru10, MOSS2000, Nilupa, hignacio43, 3fan, bigone, Vincwilson, ali akbar, anurrba, TAFATNEB, valinhas, gampang_ingat, mowafi3m, fdgTG67, jfjdm, jmanuel147, K.Lee
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
09-26-2012, 12:04 AM
No limits to creativity
[-] The following 27 users Like joker™'s post:27 users Like joker™'s post
  • kowheng, JOGAR71, knrsa, Dell_Brett, valinhas, oanm2000, ruaumoko, haze, araza023, cordoba123, emmi, ykhackhack, zrilek, Diquan, Nilupa, 3fan, nickycruz, bigone, Vincwilson, fer962933, caifan, mowafi3m, jmanuel147, DamaD, Arigato, pedzaquino, Rodmo376
 ykhackhack
United States
User ID: 36960
Threads: 81
Likes: 3,670 in 707 posts
Given Likes: 8693
11-10-2012, 12:07 PM
[-] The following 18 users Like ykhackhack's post:18 users Like ykhackhack's post
  • blaze, Diquan, joker™, zrilek, oanm2000, Dell_Brett, 3fan, nickycruz, bigone, yutt, simanta, eng donny, Nilupa, TAFATNEB, hernansgz, narendra, jfjdm, ali akbar
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
01-14-2013, 04:06 PM
RAM Elements V8i Update (Version: 13.00.02.37) 51.94 MB
[-] The following 17 users Like BennyP's post:17 users Like BennyP's post
  • RICARDI, seriousboy, oanm2000, joker™, coxxxyboy, Dell_Brett, bigone, cace-01, hzaheer, jjmtz, JOGAR71, ykhackhack, Andrew seah, zrilek, jmanuel147, Diquan, valinhas
Away  joker™
User ID: 10925
Threads: 92
Given Likes: 2426
01-19-2013, 09:33 AM
Mirror RAM Elements V8i Update (Version: 13.00.02.37) 51.94 MB
[-] The following 5 users Like joker™'s post:5 users Like joker™'s post
  • Dell_Brett, ykhackhack, bigone, zrilek, Diquan
Away  joker™
User ID: 10925
Threads: 92
Given Likes: 2426
01-19-2013, 03:04 PM
[-] The following 9 users Like joker™'s post:9 users Like joker™'s post
  • oanm2000, arinco, Dell_Brett, ykhackhack, bigone, jfjdm, zrilek, jmanuel147, Diquan
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
04-07-2013, 04:17 PM
RAM Elements V8i update
(Version: 13.00.03.45 Date: 3/28/2013 FileSize: 53.74 MB)
[-] The following 21 users Like BennyP's post:21 users Like BennyP's post
  • oanm2000, ecarkarq, mowafi3m, joker™, haze, Milkshake, aslam, simanta, ykhackhack, wesam_19701970, Andrew seah, Dell_Brett, bigone, zrilek, coxxxyboy, jmanuel147, Arigato, fretts08, ali akbar, pedrozarth, Diquan
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
08-04-2014, 11:08 AM (This post was last modified: 08-04-2014, 11:09 AM by bigone.)
RAM Elements V8i
(Version: 13.02.00.99 Date: 7/30/2014 FileSize: 124.21 MB)
RAM Elements V13.2.0 Release Notes
Updated July 2014
Enhancements
Bentley Trust Licensing has been implemented. Thanks to Trust Licensing, users can always access the software they need to get their work done. It lets users access software whenever they need it, even if a license is not available.
Full integration with RAM Connection 9.0.x that allows access to the latest connection design codes/standards.
Resolved Issues
Fix to the AISC 360-05 design for Cm factor. The moment amplification factor was not taking into account the sign convention correctly for single and reverse curvature.
Repair to the DXF display in the Concrete Beam Design module. When the user updated the reinforcing steel in the spreadsheet, the calculations and report were updated, but not the DXF display.
The deflection for cantilevered members was inaccurate. The proper equation is now being used producing precise results.
The wind load generation tool for several floors was not working. This has been fixed now.
The Fb, Ft, Fc values for Northern Pine Lumber were not up to date. Now they have been set accordingly to the NDS Addendum of March 2013.
The crash when RAM Elements users tried to design a model due to a glitch in the Welcome Screen has been eliminated.
Cracked inertia calculations equations were fixed to consider one or two reinforcement layers.
Wrong wall weights for partially grouted walls were being calculated and now this has been fixed to match TEK tables accurately.
The cracked moment of inertia calculation has been changed to consider just one reinforcement layer.
Several other minor fixes.
[-] The following 15 users Like bigone's post:15 users Like bigone's post
  • malc, ykhackhack, Dell_Brett, dl4all, zrilek, jjmtz, odiclas, joker™, oanm2000, MOSS2000, cybermad, ecarkarq, blaze, Diquan, AndresPeper
 bigone
User ID: 4505
Threads: 92
Given Likes: 7145
11-02-2014, 06:49 AM
RAM Elements V8i
(Version: 13.03.00.117 Date: 10/23/2014 FileSize: 124 MB)
[-] The following 23 users Like bigone's post:23 users Like bigone's post
  • zrilek, malc, blaze, Dell_Brett, jcbv, joker™, oanm2000, simanta, Diquan, shaker, seriousboy, aema, jfjdm, nibbi, haze, MOSS2000, Rodmo376, ykhackhack, arinco, faxel, odiclas, AndresPeper, jacky899
 ykhackhack
United States
User ID: 36960
Threads: 81
Given Likes: 8693
08-23-2015, 06:24 AM (This post was last modified: 08-23-2015, 06:27 AM by ykhackhack.)
Mirror Patch only
@nassur
[-] The following 9 users Like ykhackhack's post:9 users Like ykhackhack's post
  • zrilek, joker™, oanm2000, shaker, Dell_Brett, PinkPant, malc, AndresPeper, jacky899
  RAM Connection V8i (SELECTseries 4) 8.0.0.23 1000 days trial BennyP 12 37,131 08-18-2015, 09:00 AM
Last Post: ykhackhack
  Bentley PondPack 08.11.01.54 V8i (30 days trial and renew) BennyP 4 13,573 02-15-2015, 12:06 AM
Last Post: fayezkazi
  Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 15,626 09-09-2013, 05:23 AM
Last Post: pezhmankhan
  Bentley Watercad V8i (SELECTseries 2) 08.11.02.31 (Trial) BennyP 2 10,250 04-20-2013, 07:47 PM
Last Post: joker™
  Bentley SewerGEMS v8i (SELECTseries 2) 08.11.02.46 (Trial) BennyP 8 19,147 01-22-2013, 02:37 PM
Last Post: joker™
  STAAD.Pro V8i SELECTseries 4 (20.07.09.11) - Trial Version kardels 4 17,390 11-25-2012, 10:03 AM
Last Post: joker™
  STAAD(X) Tower V8i (SELECTseries 1) 08.02.01.48 (trial only) BennyP 2 10,959 08-19-2012, 09:03 AM
Last Post: jupe01
