Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Numerical response of steel reinforced concrete slab subjected to blast and pressure
[Request] Numerical response of steel reinforced concrete slab subjected to blast and pressure
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
06-01-2012, 08:38 AM (This post was last modified: 06-01-2012, 09:07 AM by mybest.)
Numerical response of steel reinforced concrete slab subjected to blast and pressure loadings in LS-DYNA
Author: Vivek Reddy Y (Author) | Size: ? MB | Format: PDF | Quality: Unspecified | Publisher: ProQuest, UMI Dissertation Publishing | Year: 2011 | pages: 120 | ISBN: 124459427X-978-1244594272
[Image: 68744526911456638345.jpg]
As steel reinforced concrete has got wide range of applications, this project is an attempt to study the dynamic behavior of steel reinforced concrete subjected to blast and pressure loadings using a non-linear finite element code LS-DYNA (version 971). The aim of this project was to analyze various parameters of a steel reinforced concrete slab by validating three of the concrete material models in LS-DYNA.
The first part of the project consists of validating three concrete material models in LS-DYNA by applying boundary conditions on simple single elements. The next part consists of using these three concrete material models of LS-DYNA (version 971) for the study of blast and pressure load analysis on a steel reinforced concrete slab for two different strengths of concrete with two different mesh sizes.
The main purpose of this analysis was to provide the behavior of these concrete material models subjected to blast loads, which would be a better guide for future applications.
  [REQUEST] Analysis and design of structural concrete elements subjected to in- plane forces ch_surf 0 1,342 06-23-2014, 03:34 PM
Last Post: ch_surf
  [REQUEST] Sloshing Response of Floating Roofed Liquid Storage Tanks Subjected to Earthquakes of ssobhan 1 1,730 02-22-2014, 07:02 AM
Last Post: Mohammad6299
  [REQUEST] Predicting reinforced concrete response to blast loads ssobhan 1 1,727 02-03-2014, 08:35 AM
Last Post: ska51
  [REQUEST] Numerical Modeling of Buried HDPE Pipelines Subjected to Normal Faulting: A Case Stud ssobhan 0 1,429 01-15-2014, 12:27 PM
Last Post: ssobhan
  [REQUEST] Iso-response Analysis of Blast Loaded Stiffened Plates s0p9015 2 2,199 09-17-2013, 11:25 AM
Last Post: ssobhan
  [REQUEST] Blast Mitigation: Experimental and Numerical Studies ssobhan 0 1,265 08-22-2013, 09:07 AM
Last Post: ssobhan
  [REQUEST] influence of connection modelling on seismic response of moment resisting steel frame DamirDz 1 1,591 03-11-2013, 07:27 AM
Last Post: ssobhan
