Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM A578 / A578M - 07
 nassara
User ID: 11225
Threads: 17
Likes: 596 in 44 posts
Given Likes: 105
04-01-2012, 09:47 PM (This post was last modified: 04-02-2012, 01:07 AM by Dell_Brett.)
Author: ASTM Committee A01 | Size: 82 KB | Format: PDF | Quality: Original preprint | Publisher: ASTM International | Year: 2007 | pages: 05
[Image: 53706713602226874325.jpg]
Standard Specification for Straight-Beam Ultrasonic Examination of Rolled Steel Plates for Special Applications
Abstract
This procedure covers the standard and acceptance standards for straight-beam, pulse-echo, ultrasonic examination of rolled carbon and alloy steel plates. The amplitude linearity of the apparatus to be used shall be checked by positioning the transducer over the depth resolution notch in the IIW or similar block. The inspection shall be performed in an area free of operations that interfere with proper performance of the test. The test shall be performed either by direct contact, immersion, or liquid column coupling. Grid scanning shall be conducted along a continuous perpendicular line on the center. All discontinuities causing complete loss of reflection shall be recorded.
This abstract is a brief summary of the referenced standard. It is informational only and not an official part of the standard; the full text of the standard itself must be referred to for its use and application. ASTM does not give any warranty express or implied or make any representation that the contents of this abstract are accurate, complete or up to date.
1. Scope
1.1 This specification covers the procedure and acceptance standards for straight-beam, pulse-echo, ultrasonic examination of rolled carbon and alloy steel plates, 3/8 in. [10 mm] in thickness and over, for special applications. The method will detect internal discontinuities parallel to the rolled surfaces. Three levels of acceptance standards are provided. Supplementary requirements are provided for alternative procedures.
1.2 Individuals performing examinations in accordance with this specification shall be qualified and certified in accordance with the requirements of the latest edition of ASNT SNT-TC-1A or an equivalent accepted standard. An equivalent standard is one which covers the qualification and certification of ultrasonic nondestructive examination candidates and which is acceptable to the purchaser.
1.3 The values stated in either SI units or inch-pound units are to be regarded separately as standard. The values stated in each system may not be exact equivalents; therefore, each system shall be used independently of the other. Combining values from the two systems may result in non-conformance with the standard.
1.4 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
Moderator Note;
thanks for your excellent post, but the forum template password must be "www.civilea.com"
[-] The following 6 users Like nassara's post:6 users Like nassara's post
  • kowheng, st77bel, NBZ1400, rkce, utan, knrsa
  ASTM 2005 - ASTM Dictionary of ENGINEERING SCIENCE & TECHNOLOGY, 10th ed abudabeeja 2 4,307 01-23-2022, 10:22 AM
  ASTM - Mega Collection of ASTM Standards (UPDATED REGULARLY) junaid 1 3,022 11-09-2017, 11:49 PM
Last Post: usman
  ASTM D4839 - 03(2011) | ASTM D2435 / D2435M - 11 | ASTM D2487 - 11 mybest 0 2,147 12-30-2011, 12:21 AM
Last Post: mybest
  ASTM Standards Collections - ASTM International Tamilan 105 63,119 10-29-2011, 12:17 PM
Last Post: hich
  ASTM - User's Guide to ASTM Specification C94 on Ready-Mixed Concrete ibg0203 1 2,569 12-09-2010, 05:29 PM
  ASTM STP1377 - ASTM's Role in Performance-Based Fire Codes and Standards pezhmankhan 0 1,996 09-04-2010, 04:36 AM
Last Post: pezhmankhan
