Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM C494/C494M-11 Standard Specification for Chemical Admixtures for Concrete
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
01-03-2012, 12:52 PM (This post was last modified: 01-03-2012, 12:58 PM by mybest.)
Size: 221 KB | Format: PDF | pages: 10
[Image: 66298948667798398782.png]
This specification covers the materials and the test methods for use in chemical admixtures to be added to hydraulic-cement concrete mixtures in the field. The seven types of admixtures are indicated as follows: Type A—water reducing; Type B—retarding; Type C—accelerating; Type D—water reducing and retarding; Type E—water reducing and accelerating; Type F—water reducing, high range; and Type G—water reducing, high range, and retarding. The materials used in the concrete mixtures shall include Type I or Type II cement, pozzolan, fine and coarse aggregates, and air-entraining admixture. Samples of freshly mixed concrete from at least three separate batches for each condition of concrete shall be tested in accordance with the slump, air content, time of setting, and water content tests. Physical properties retesting shall consist of uniformity and equivalence tests using infrared analysis which is intended to compare qualitatively the composition of different samples, residue by oven drying which shall be either a forced circulation type or one with provision for free access of air, and specific gravity determination using hydrometers. Test specimens of the hardened concrete shall be prepared in accordance to compressive strength, flexural strength, resistance to freezing and thawing, and length change.
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  • kowheng, Dell_Brett, Jackass, ir_71, malc, p_vosoughi, nickycruz
05-30-2014, 04:27 PM
ASTM C494/C494M – 12 Standard Specification for Chemical Admixtures for Concrete
Author: Subcommittee C09.23 | Size: 0.1 MB | Format: PDF | Quality: Original preprint | Publisher: ASTM | Year: 2012 | pages: 10
[Image: 33568011391972069747.jpg]
  • vardan, Mohammad6299, zrilek, rezart, pezhmankhan, PinkPant, knrsa, Dell_Brett
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,792 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,137 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,915 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,976 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,178 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,236 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,810 10-28-2023, 06:32 AM
