Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM C150/C150M-11 Standard Specification for Portland Cement
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
01-03-2012, 12:50 PM
Size: 200 KB | Format: PDF | pages: 9
[Image: 98798075219764820437.png]
This specification covers ten types of portland cement: Type I, Type IA, Type II, Type II(MH), Type II(MH)A, Type IIA, Type III, Type IIIA, Type IV, and Type V. The cement covered by this specification shall only contain the following ingredients: portland cement clinker; water or calcium sulfate, or both; limestone; processing additions; and air-entraining addition for air-entraining portland cement. Portland cements must meet various physical and chemical requirements which are detailed in this specification. Examples include limits on aluminum oxide, ferric oxide, magnesium oxide, sulfur trioxide, tricalcium silicate, dicalcium silicate, tricalcium aluminate, and tetracalcium aluminoferrite. Applicable properties enumerated in this specification will be determined by the following test methods: air content of mortar, chemical analysis, compressive strength, false set, fineness by air permeability, fineness by turbidimeter, heat of hydration, autoclave expansion, time of setting by Gillmore needles, time of setting by Vicat needles, sulfate resistance, calcium sulfate, and compressive strength. The cement shall be stored in such a manner as to permit easy access for proper inspection and identification of each shipment, and in a suitable weather-tight building that will protect the cement from dampness and minimize warehouse set.
[-] The following 10 users Like mybest's post:10 users Like mybest's post
  • kowheng, Dell_Brett, Jackass, ir_71, malc, chatxxnoir, arceon, Hengki, heogay43, visu
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,792 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,135 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,914 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,975 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,177 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,235 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,808 10-28-2023, 06:32 AM
