Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM A615 / A615M - 09b Standard Specification for Deformed and Plain Carbon-Steel Ba
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
02-04-2012, 03:31 PM
ASTM A615 / A615M - 09b Standard Specification for Deformed and Plain Carbon-Steel Bars for Concrete Reinforcement
Size: 143 KB | Format: PDF | Quality: Original preprint | pages: 6
[Image: 44507730641567205233.png]
This specification covers deformed and plain carbon-steel bars for concrete reinforcements in cut lengths and coils. Materials considered under this specification are available in Grades 40 [280], 60 [420], and 75 [520]. Steel samples shall be rolled from properly identified heats of mold cast or strand cast steel using electric-furnace, basic-oxygen, or open-hearth. Heat analysis shall be performed wherein steel materials shall conform to required compositions of carbon, manganese, phosphorus, and sulfur. Steel specimens shall also undergo tensile tests and shall conform to required values of tensile strength, yield strength, and elongation. Steel samples shall also undergo deformation test, tension test and bend tests. Final products shall be marked by a tag.
[-] The following 10 users Like mybest's post:10 users Like mybest's post
  • malc, kowheng, Dell_Brett, knrsa, blaze, Jackass, nhim4mat2006, simanta, pmg814, bigone
 ykhackhack
United States
User ID: 36960
Threads: 81
Likes: 3,670 in 707 posts
Given Likes: 8693
01-27-2015, 04:32 AM
use forum password
@photon
[-] The following 10 users Like ykhackhack's post:10 users Like ykhackhack's post
  • amindoxiti, malc, Dell_Brett, subin91, bridgeengineer, PinkPant, Photon, bigone, uncblue, oanm2000
 nibbi
User ID: 21150
Threads: 6
Likes: 464 in 21 posts
Given Likes: 182
01-28-2015, 03:49 PM
ASTM A615-14 - Deformed and Plain Carbon-Steel Bars for Concrete Reinforcement
Size: 108 KB | Format: PDF | Quality: Original preprint | Year: 2014
[-] The following 9 users Like nibbi's post:9 users Like nibbi's post
  • bridgeengineer, viet2010, aslam, malc, PinkPant, Photon, oanm2000, simanta, CAMSECT
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 2,760 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,103 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 2,877 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 2,940 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,140 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,195 11-01-2023, 07:18 AM
  ASTM D2573/D2573M: Standard Test Method for Field Vane Shear Test in Saturated Fine-G poolmand 0 2,744 10-28-2023, 06:32 AM
