Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general How to Build a Reinforced Besser Block Retaining Wall
Away  joker™
User ID: 10925
Threads: 92
Likes: 7,246 in 938 posts
Given Likes: 2426
01-29-2012, 09:04 AM
[Image: 25512513810145419479.png]
Reinforced Besser Block Retaining and Basement Walls consist of a reinforced concrete base which anchors the wall against overturning and sliding, and a stem of Besser blocks. The stem is reinforced with steel bars placed vertically and horizontally, and all cores in the blocks are filled with semi-fluid concrete, known as ‘grout’. The vertical reinforcing bars in the cores are lapped with shorter ‘starter bars’ embedded firmly in the reinforced concrete base using a hob to correctly locate the bars. These short bars allow easier blocklaying, and the longer bars are put in after all blocks are laid and before grouting. The length of the lap is critically important and must be shown on the drawings
No limits to creativity
[-] The following 12 users Like joker™'s post:12 users Like joker™'s post
  • dbsimon29, techno, malc, Dell_Brett, Josep Soroz, oanm2000, Jackass, zrilek, cepot, kowheng, pedzaquino, gulilero
09-06-2012, 05:09 AM
Direct Link :Wink
[-] The following 10 users Like shadabg's post:10 users Like shadabg's post
  • kowheng, knrsa, hapsea, gulilero, oanm2000, harsono, ruaumoko, narendra, spat, blaze
  Basics of Retaining Wall Design - by Hugh Brooks OSHO 15 16,155 11-30-2024, 10:56 AM
Last Post: civilfafa
  Guidance on embedded retaining wall design (CIRIA C760) jacs1976 1 3,706 10-27-2021, 03:07 AM
Last Post: concreteok
  Guide to Retaining Wall Design ir_71 4 5,207 10-16-2012, 09:15 PM
Last Post: Ernest0
  Block wall design manual jacs127 1 2,133 11-21-2011, 02:08 AM
Last Post: 3fan
  Moments & Reactions for Rectangular Plates (design of Counterfort Retaining wall) vsa2010 0 2,702 08-06-2011, 05:53 AM
Last Post: vsa2010
