Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8233:1999 Sound insulation and noise reduction for buildings. Code of practice
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
01-25-2012, 03:42 PM (This post was last modified: 01-25-2012, 03:43 PM by mybest.)
Size: 843 KB | Format: PDF | Quality: Original preprint | Publisher: BSI Group | Year: 15 August 1999 | pages: 56 | ISBN: 0 580 33009 5
[Image: 40591550538558453570.png]
This British Standard gives recommendations for the control of noise in and around buildings, and suggests appropriate criteria and limits for different situations. These criteria and limits are primarily intended to guide the design of new or refurbished buildings undergoing a change of use, rather than to assess the effect of changes in the external noise level. This standard covers room acoustics for simple situations, but not the design of buildings where the acoustics are critical, such as auditoria.
This code of practice does not cover vibration control, except where it is evident in the form of radiated sound.
Recommendations for the control of noise in and around buildings and suggestions for appropriate criteria and limits for different situations. Room acoustics for simple situations is covered, but the design of buildings where the acoustics are critical, such as auditoria, is outside the scope.
Replaces BS 8233:1987
[-] The following 11 users Like mybest's post:11 users Like mybest's post
  • malc, hcardenas, 3fan, Jackass, kowheng, vpmohammed, Billi Corgan, peixoto, Dell_Brett, ir_71, zrilek
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
02-21-2013, 01:15 PM
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,380 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,600 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,246 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,129 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,383 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,748 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,317 02-17-2021, 11:20 AM
Last Post: temp1366
