Civil Engineering Association eBooks General Books Mechanics & Material Technology (Elasticity, Plasticity and Nonlinearity) Minimization of welding distortion and buckling: Modelling and implementation
 cordoba123
User ID: 1196
Threads: 221
Likes: 5,490 in 485 posts
Given Likes: 1618
01-22-2012, 12:00 AM
Minimization of welding distortion and buckling: Modelling and implementation >> Edited by P Michaleris, Penn State University, USA
Author: Edited by P Michaleris, Penn State University, USA | Size: 15.92 MB | Format: PDF | Quality: Original preprint | Publisher: Woodhead Publishing Limited | Year: May 2011 | pages: 314 | ISBN: ISBN 1 84569 662 X ISBN-13: 978 1 84569 662 7
[Image: 53791437975892034030.jpg]
[Image: 43424226050884575979.jpg]
- provides a systematic overview of the methods of minimizing distortion and buckling in welded structures
- focuses on understanding welding stress and distortion featuring computational welding mechanics and modelling the effect of phase transformations
- explores different methods of minimizing welding distortion discussing differential heating and dynamic thermal tensioning
Welding is a cost-effective and flexible method of fabricating large structures, but drawbacks such as residual stress, distortion and buckling must be overcome in order to optimize structural performance. Minimization of welding distortion and buckling provides a systematic overview of the methods of minimizing distortion and buckling in welded structures.
Following an introductory chapter, part one focuses on understanding welding stress and distortion, with chapters on such topics as computational welding mechanics, modelling the effect of phase transformations on welding stress and distortion and using computationally efficient reduced-solution methods to understand welding distortion. Part two covers different methods of minimizing welding distortion. Chapters discuss methods such as differential heating for minimizing distortion in welded stiffeners, dynamic thermal tensioning, reverse-side heating and ways of minimizing buckling such as weld cooling and hybrid laser arc welding.
With its distinguished editor and international team of contributors, Minimization of welding distortion and buckling is an essential reference for all welders and engineers involved in fabrication of metal end-products, as well as those in industry and academia with a research interest in the area.
Contents
PART 1 UNDERSTANDING WELDING RESIDUAL STRESS AND DISTORTION
PART 2 MINIMIZING WELDING DISTORTION
Introduction to welding residual stress and distortion
- Types of welding distortion
- Formation of welding distortion
- Distortion control methods
- Book outline
- References
Understanding welding stress and distortion using computational welding mechanics
L-E Lindgren, Luleå University of Technology, Sweden
- Introduction
- The Satoh test
- Thermo-mechanical analysis of welding problems
- Eularian and Lagrangian reference frames
- Nonlinear heat conduction
- Nonlinear deformation
- Finite element techniques in computational welding mechanics (CWM)
- Heat input models
- Material models
- References
Modelling the effects of phase transformations on welding stress and distortion
J A Francis and P J Withers, University of Manchester, UK
- Introduction
- Types of transformation
- Transformation strains
- Equilibrium phase diagrams
- Continuous cooling transformation (CCT) diagrams
- Significance of transformation temperature
- Metallurgical zones in welded joints
- Effects of phase transformations on residual stresses in welds
- Transformation plasticity
- Current status of weld modelling
- References
Modelling welding stress and distortion in large structures
L Zhang, Link-Belt Construction Equipment, USA
- Introduction
- 3D applied plastic strain methods
- Application on a large structure
- Conclusions
- References
Using computationally-efficient, reduced-solution methods to understand welding distortion
T G F Gray, University of Strathclyde, UK and D Camilleri, University of Malta, Malta
- Introduction
- Context and rationale for reduced solution methods
- Computationally-efficient solutions based on mismatched thermal strain (MTS) and transverse contraction strain (TCS) algorithms
- Verification of MTS and TCS algorithms
- Multiple welds
- Fillet welds
- Hybrid and stepwise strategies
- Selected case studies
- Future trends
- Sources of further information and advice
- References
Minimization of bowing distortion in welded stiffeners using differential heating
M V Deo, Cummins Inc., USA
- Introduction
- Welding induced residual stress and bowing distortion
- Mitigation of welding induced bowing distortion
- Experimental verification of transient differential heating
- Results
- Conclusions
- References
Dynamic thermal tensioning for controlling welding induced distortion
W Li, The University of Texas at Austin and J Xu, Strategic Global Sourcing, USA
- Introduction
- A simplified finite element model
- The dynamic thermal tensioning method
- Mitigating buckling distortion using the dynamic thermal tensioning method
- Conclusions
- References
Minimizing buckling distortion in welding by weld cooling
J Li, Beijing Aeronautical Manufacturing Technology Research Institute and Q-Y Shi, Tsinghua University, P. R. China
- Introduction
- Welding with intensive trailing cooling, the dynamically controlled low stress no distortion
- (DC-LSND) method and its influence on welded joint (structure)
- Mechanism of DC-LSND method
- Restriction and industry application
- Conclusions
- References
Minimizing buckling distortion in welding by hybrid laser arc welding
S M Kelly, R P Martukanitz and E W Reutzel, Pennsylvania State University, USA
- Laser beam welding
- Hybrid laser arc welding (HLAW)
- Hybrid laser arc welding for reducing distortion in marine construction
- Conclusions
- References
Minimizing angular distortion in welding by reverse-side heating
M Mochizuki, Osaka University, Japan
- Introduction
- Experimental
- Mechanism of reduction in welding distortion
- Conclusions
- Acknowledgements
- References
[-] The following 9 users Like cordoba123's post:9 users Like cordoba123's post
  • gulilero, Jackass, Dell_Brett, kowheng, malc, slowet, tluc, eliseo.as, fer962933
  Minimization of welding distortion and buckling , Modelling and implementation fred2010 0 1,413 07-03-2013, 08:44 PM
Last Post: fred2010
