ETABS Load Combo Sheet
Current time: 05-11-2021, 02:49 PM
Author: RANA WASEEM
Last Post: orass
Replies 6
Views 7779
Have a look at it...may be u find it useful...its for manually creating combos in excel and then importing back to etabs..as it allows the flexibility to create combinations in table format and less chances for errors as compared with that of ETABS unfriendly load combo interface...Report back any bugs or suggestions...thanks
*PROCEDURE
Create the model in ETABS
Atleast make one load combinations..after defining load cases...
Then Use this Sheet
WS
[-] The following 12 users say Thank You to RANA WASEEM for this post:
  • julioreptil, ramaprasadsr, Batman07, malc, isurya, pedzaquino, jaks, learner20, yyyready, yeka, ruaumoko, bigone
Dear coolestbliss,
Thanks for the excellent work!
Just a few question on how to use the excel sheet.
For step1: I can only have 6 types of load cases being the 1st the self weight, then any load case and the 6th is always the main lateral load case?, and i cannot leave a column blank also or is only the rows?, because lets say i only have selfweight, live and seismic, the rest of the columns are blank?
The combinations with the +/- signs are generated automatically right? (wind and seismic)
Now, lets say i made all the combos and everything... then step5, then step6 and ask me for a text file... why?
Now lets say a double click my text file ($et file) and the problem is the gives me an error
So... can you explain everything a little bit please...
Thanks!
Diquan
(11-10-2011, 02:00 AM)Diquan Wrote: For step1: I can only have 6 types of load cases being the 1st the self weight, then any load case and the 6th is always the main lateral load case?, and i cannot leave a column blank also or is only the rows?, because lets say i only have selfweight, live and seismic, the rest of the columns are blank?
YES YOU CAN LEAVE BLANK COLUMNS ...but not rows
(11-10-2011, 02:00 AM)Diquan Wrote: The combinations with the +/- signs are generated automatically right? (wind and seismic)
NO! it doesnt generate +/- automatically..instead i used a different approach..LETS say you have x and y directions for WIND..you can define Positive X and Negative X..as WND-PX and WND-NX...and then apply the manual loads wind loads in positive and negative direction as is the case in WIND LOAD FROM AREA EXTENTS IN ETABS...if you want to include +/- signs..you will have to change that signs your self..but dont worry..i will work out for this feature too..keep suggesting..
(11-10-2011, 02:00 AM)Diquan Wrote: Now, lets say i made all the combos and everything... then step5, then step6 and ask me for a text file... why?
IF YOU WILL NOT SPECIFIY THE $ET FILE..HOW THE EXCEL SHEEL WILL WRITE COMBINATIONS IN ETABS TEXT FILE FOR YOU?
(11-10-2011, 02:00 AM)Diquan Wrote: Now lets say a double click my text file ($et file) and the problem is the gives me an error
it gives you error because you dont have a necessary windows file for file system object[b]
WS
[-] The following 1 user says Thank You to RANA WASEEM for this post:
  • jaks
Dear coolestbliss,
Ok, thanks!, i will work on weekend in studying the sheet building an example... i really like the idea of creating the combos in a more easier way, because ETABS is like an old age program to input these things!, not like in SAP where you can input that in a excel file.
Thanks again,
Diquan
[-] The following 1 user says Thank You to Diquan for this post:
  • RANA WASEEM
Hi ersin,
Try this:
Batman07
"If I had eight hours to chop down a tree, I'd spend six sharpening my ax. "- A. Lincoln
[-] The following 9 users say Thank You to Batman07 for this post:
  • RANA WASEEM, jaks, Dell_Brett, seriousboy, yyyready, yeka, ersin, sodapas, bigone
sorry guyz! actually i moved all the files from 4shared to google sites you so dont have to wait for download waiting time!
but i didnt post the update here so here is the link in which u will find all of my work on my blog including this etabs load combo
WS
[-] The following 5 users say Thank You to RANA WASEEM for this post:
  • Diquan, sodapas, malc, araza023, bigone
all links are not valid pls reload it
