Civil Engineering Association eBooks Journals, Papers and Presentations Innovative Seismic Design Procedure for Frame-Wall Structures
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
10-11-2011, 03:52 PM
Author: Sullivan, Priestley & Calvi | Size: 0.6 MB | Format: PDF | Publisher: Imperial College Press | Year: 2005 | pages: 29
This useful article is authored by Dr TJ Sullivan with his former advisors, Professors MJN Priestley and GM Calvi. It explains a new procedure of seismic design of frame-wall structures based on displacement-based design method.
Abstract:
A displacement-based design (DBD) methodology for structures that are comprised of both frames and walls has been proposed and then tested through examination of several case studies. Strength proportions between walls and frames are decided before any analysis has begun. The various steps required to represent a frame-wall structure as a single-degree of freedom system are identified and a Direct DBD process is then adopted to set the required strength level. To test the design methodology, two sets of 4, 8, 12, 16 and 20-storey reinforced concrete structures are designed, with different proportions of the total strength assigned to the frames.
[-] The following 12 users Like Sumatra's post:12 users Like Sumatra's post
  • gulilero, Dell_Brett, zrilek, faros3000, Adam Smith, malc, Jackass, cace-01, ting tsai huang, kowheng, blaze, fer962933
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,361 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Seismic Design of Concrete Structures - The Present Needs of Societies RyanRS 0 5,521 05-17-2015, 05:49 AM
Last Post: RyanRS
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,630 02-12-2015, 01:39 PM
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,860 12-26-2014, 09:49 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,098 10-08-2014, 02:06 PM
  Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 4,995 09-05-2014, 02:03 PM
  Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 6,032 09-05-2014, 01:59 PM
