Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Deformation Analysis in Soft Ground Improvement
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
07-18-2011, 09:33 AM (This post was last modified: 07-20-2011, 08:44 PM by usman.)
Author: Jinchun Chai, John P. Carter | Size: 3.5 MB | Format: PDF | Publisher: Springer | Year: 2011 | pages: 266 | ISBN: 9789400717206
[Image: 04566743838706160661.jpg]
This book deals with the behaviour of soft ground improved by some of the more common methods, including the installation of prefabricated vertical drains (PVDs), or the installation of soil-cement columns formed by deep mixing, or the preloading of soft ground by application of a vacuum pressure in addition to, or instead of, a surcharge loading. In particular, it describes the theories and the numerical modelling techniques that may be applied to these soft ground improvement schemes to estimate the immediate and time-dependent mechanical response of the in situ soil. Particular emphasis has been placed on methods that reliably predict ground deformations associated with ground improvement techniques.The book commences with a brief description of the various ground improvement methods and then describes general techniques for modelling the behaviour of soft clay subsoils by the finite element method, as well as details of the methods for modelling soft soils improved by the installation of PVDs. It also includes chapters describing the theory of vacuum consolidation and methods for calculating vacuum pressure-induced ground deformation, as well as a theory which can be used to predict the response of soft ground improved by the installation of soil-cement columns. An important distinguishing feature of this book is the routine use of comparisons of predictions of the proposed models with the results of laboratory studies, and particularly field case studies, in order to validate the proposed methods of analysis. The field case histories are from soft soil sites at various locations around the world.The book is directed towards students of geotechnical engineering as well as geotechnical practitioners. In the main it provides complete derivations of most of the important theoretical results, as the intention was to write a book that could be used as both a teaching text and a reference work for students and practitioners.Audience: The book is intended for geotechnical practitioners as well as for students.
[-] The following 25 users Like cace-01's post:25 users Like cace-01's post
  • kowheng, Dell_Brett, theanhpe, malc, isurya, tynhanh, utan, cigutierrezg, blaze, oanm2000, Jackass, Evandrojr, myplaxis, kaci, jacs127, zrilek, tluc, dede, momo2010, jaejeong, gibran, vijayakumarr, Gkatzogias, techno, nhim4mat2006
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
07-20-2011, 04:26 PM
Deformation Analysis in Soft Ground Improvement (Geotechnical, Geological and Earthquake Engineering)
Author: Jinchun Chai | Size: 3.50 MB | Format: PDF | Publisher: Springer | Year: 2011 | pages: 302 | ISBN: 9400717202
Product Description:
"Downstream is Weaker"
[-] The following 8 users Like ska51's post:8 users Like ska51's post
  • 3fan, Jackass, Clouseau, oanm2000, techno, nhim4mat2006, shadabg, Gkatzogias
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
07-20-2011, 04:40 PM
[-] The following 10 users Like 3fan's post:10 users Like 3fan's post
  • Jackass, Clouseau, oanm2000, cristi, peymanlord, gulilero, Dell_Brett, nhim4mat2006, shadabg, slowet
04-21-2012, 03:41 AM
Bookmarked PDF 3.64 MB
[-] The following 7 users Like kowheng's post:7 users Like kowheng's post
  • Dell_Brett, Jackass, geocivil, nhim4mat2006, daywalker, shadabg, lisine
08-14-2012, 08:33 AM
[-] The following 2 users Like shadabg's post:2 users Like shadabg's post
  • nhim4mat2006, pousin
  Ground Improvement and Reinforced Soil Structures: Proceedings of Indian Geotechnical poolmand 0 1,487 08-02-2021, 06:36 AM
  Geotechnical Aspects of Underground Construction in Soft Ground poolmand 0 1,588 07-18-2021, 10:52 AM
  Soil Improvement and Ground Modification Methods junaid 5 4,478 08-24-2020, 09:49 AM
Last Post: malc
  Ground Improvement By Deep Vibratory Methods PinkPant 3 2,905 01-18-2019, 11:15 AM
Last Post: scorpion07
  Ground and Soil Improvement toa011 5 4,707 03-06-2017, 02:09 PM
  Ground Improvement, Volume 3: Case Histories (Geo-Engineering Book Series) Hamza-MKD 7 5,182 12-06-2016, 04:56 AM
Last Post: ska51
  Principles and Practice of Ground Improvement cace-01 2 2,764 06-30-2015, 06:23 PM
