Civil Engineering Association eBooks Journals, Papers and Presentations Buckling-restrained braces for seismic upgrading
 Apache
User ID: 261
Threads: 28
Likes: 575 in 49 posts
Given Likes: 199
03-31-2011, 08:01 PM
[Image: 94649938882128170602.jpg]
Buckling-Restrained Braces (BRBs) are a relatively recent development in the field of seismic resistant steel
structures. BRBs can be considered a structural system much more efficient than classic concentric braces (CCBs) to resist earthquakes because they exhibit an almost symmetric load-deformation behaviour and larger energy absorption capacity. Results of an experimental campaign consisting of full scale tests on two reinforced concrete (RC) buildings equipped with BRBs are presented and discussed. The experimental activity led to develop a novel “all-steel” BRB, which has been specifically designed for seismic upgrading of RC buildings, without interference with their functions and aesthetics. Indeed, the main characteristic of the novel braces is the possibility to hide them within the space between the two panels of masonry infill walls commonly used for claddings of RC buildings.
[-] The following 7 users Like Apache's post:7 users Like Apache's post
  • malc, civilteam, zainseiya, kowheng, zrilek, Clouseau, monter
  Evaluation of Concrete Cracking due to Restrained Thermal Loading and Shrinkage wafiullah 2 8,747 11-26-2020, 09:55 AM
Last Post: Dell_Brett
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,056 10-08-2014, 02:06 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,277 11-28-2013, 12:06 PM
  Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 5,678 11-28-2013, 11:58 AM
  Influence of diagonal braces in RCC multi-storied frames under wind loads: A case stu TAFATNEB 0 3,966 11-25-2013, 04:36 PM
  Seismic design of steel structures with buckling-restrained knee braces asim99 1 5,069 04-06-2013, 06:49 PM
Last Post: arshiakh
  Stitch Spacing and Local Buckling in Seismic‐Resistant Double‐Angle Braces asim99 0 3,646 04-03-2013, 04:46 PM
Last Post: asim99
