Civil Engineering Association Software Software Product Autodesk Products Autodesk Simulation Multiphysics 2012
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
03-29-2011, 03:41 PM (This post was last modified: 03-30-2011, 04:41 AM by BennyP.)
Autodesk Simulation Multiphysics 2012 x32 x64 ISZ | 1.6 GB
Autodesk Simulation provides a large set of engineering analysis tools, which enables designers and engineers already in the initial stage of the design cycle mechanism, site, or the details get close to exact product specifications. And along with it - to improve design, increase reliability, reduce time and cost of production, as well as to facilitate interaction between the different actors involved in product design.
The following types of engineering analysis can be performed:
- static stress and fatigue strength;
- the dynamic loads in the linear region of deformation of materials;
- natural frequencies (modal analysis);
- range of reactions;
- fixed and random vibration;
- stability analysis;
- Shock;
- contact analysis;
- Stationary and time-varying heat transfer and heat transfer;
- steady and unsteady flow;
- Flow in porous media;
- Flow in open channels;
- Mass transfer;
- electrostatics.
Installed in Windows 7 64 bit. Use 667D1 as code.
[Image: 20268368015320948068.gif]
[Image: 17109801087119018369.gif]
Torrent link:
RAR Password FromCivilEA
[-] The following 11 users Like BennyP's post:11 users Like BennyP's post
  • rezart, foxxx2010, warrior68, niki102, jcbv, zrilek, seriousboy, oanm2000, Ultra Zone, malc, vccalderon
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
03-30-2011, 03:57 AM
Other links:
[-] The following 5 users Like BennyP's post:5 users Like BennyP's post
  • niki102, jcbv, zrilek, rezart, oanm2000
 niki102
User ID: 8143
Threads: 85
Likes: 2,495 in 189 posts
Given Likes: 845
03-30-2011, 04:48 AM (This post was last modified: 03-30-2011, 05:11 AM by niki102.)
Autodesk Simulation Multiphysics 2012 x32 / x64 1GB*x Links
1.68 GB
1 GiG Links
Size 1.68 GB
[-] The following 4 users Like niki102's post:4 users Like niki102's post
  • jcbv, zrilek, rezart, oanm2000
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
03-30-2011, 07:25 PM
Other links:
  • rezart, zrilek, oanm2000
 niki102
User ID: 8143
Threads: 85
Given Likes: 845
03-31-2011, 01:02 AM (This post was last modified: 03-31-2011, 01:04 AM by niki102.)
AUTODESK SIMULATION MULTIPHYSICS v2012 X32 / X64 (MULTI)
[torrent - 3.95 GB ISO]
date: March 30th, 2011
type: 3D
Description:
Autodesk Simulation software, part of the Autodesk solution for Digital Prototyping,
provides a range of mechanical simulation tools to help designers and engineers
make decisions earlier in the design process. Support for multi-CAD environments
and extensive finite element modeling tools help manufacturers study initial design
intent and accurately predict product performance. Autodesk Simulation allows you
to validate and optimize designs before manufacturingΓΓé¼ΓÇ¥increasing efficiency,
minimizing reliance on physical prototypes, reducing costs, and decreasing errors.
Installation:
Unpack, burn or mount with D-Tools & install.
Check Crack/install.txt on DVD1
No Lame Patching, no problems with updates, no problems exporting
to a "legal" version, no trial patched, no files modified etc ...
The one and only way to do it - KEYGEN - fully activated
Enjoy!
Category: Windows
Files: File Name Size
asmulti.iso 3.95 GB
nfo.nfo 1.10 KB
2 files
Added: 30/03/2011
Uploader: Chris-Aksel
Downloaded: 0 times
Info Hash: 7b52244bbc0d4a896d3d8504e1e7711dcb0ce220
[-] The following 3 users Like niki102's post:3 users Like niki102's post
  • davegabj, zrilek, oanm2000
 braunfish
Italy
User ID: 1181
Threads: 13
Likes: 7 in 3 posts
Given Likes: 14
04-01-2011, 08:03 AM
which is the difference between "multiphysics" and "mechanical" simulation software?
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
04-01-2011, 09:21 AM
This is Autodesk Algor Simulation splitted in two versions. Autodesk site still doesn't supply any description for this 2012 version and the software still not appears in site as NEW RELEASE.
The description i found for the licked releases is the same but in a torrent site someone wrote the mechanical doesn't includes CFD (fluid dynamics) and this make sense.
  • braunfish, oanm2000
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
04-02-2011, 07:30 AM
Other link:
  • zrilek, oanm2000
  Autodesk Products 2012 x-force keygen for x32 systems BennyP 7 17,929 03-07-2025, 10:37 AM
  Autodesk Simulation CFD 2013 (x86/x64) Mohammad6299 4 9,837 09-12-2013, 04:52 AM
Last Post: Mohammad6299
  Autodesk AutoCAD Plant3D 2012 (x86/x64) BennyP 6 11,183 01-17-2013, 05:47 PM
  Autodesk AutoCAD LT 2012 x32 x64 ISO BennyP 12 19,887 12-17-2012, 03:32 PM
  AutoDesk Simulation Multiphysics 2013 (x32/x64/Multilanguage) Mohammad6299 1 5,921 11-05-2012, 05:12 PM
  Autodesk Subscription 2012 MegaPack BennyP 9 16,923 03-18-2012, 08:36 PM
Last Post: oasis_tree
  Autodesk AutoCAD Structural Detailing 2012 x32 x64 BennyP 18 31,576 03-01-2012, 02:19 PM
