Civil Engineering Association eBooks General Books Seismic Design and Retrofit of Piping Systems
 Hengki
User ID: 17300
Threads: 29
Likes: 437 in 30 posts
Given Likes: 1678
03-22-2011, 02:57 AM
‪Seismic Design and Retrofit of Piping Systems‬
Author: George Antaki, Aiken, SC | Size: 2.234 MB | Format: PDF | Publisher: American Lifelines Alliance (ALA) | Year: 2002 | pages: 119
[Image: 36291726678362581531.jpg]
The guide addresses the seismic design of piping systems or the retrofit of existing piping systems. The purpose of seismic design or retrofit is to assure that in case of earthquake, the piping system will perform its intended function: position retention (the pipe would not fall), leak tightness (the pipe would not leak), or operability (the piping system would deliver and regulate flow).
This Guide applies to above ground piping systems, which - except for seismic design – otherwise comply with the provisions of the ASME B31 pressure piping codes for materials, design, fabrication, examination and testing. For buried piping and pipelines, the reader is referred to an earlier ALA report “Guidelines for the Design of Buried Steel Pipe”, July 2001.
DIRECT LINKS thumbup
[-] The following 14 users Like Hengki's post:14 users Like Hengki's post
  • melkat, usman, kowheng, cace-01, malc, fashion, seriousboy, 3fan, gulilero, cigutierrezg, julioreptil, blaze, oanm2000, tluc
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
03-22-2011, 09:27 PM
Mirror links
[-] The following 4 users Like 3fan's post:4 users Like 3fan's post
  • kowheng, Grunf, oanm2000, julioreptil
  Piping and Pipeline Engineering: Design, Construction, Maintenance, Integrity, Repair cordoba123 3 3,218 04-15-2014, 04:14 PM
Last Post: Mohammad6299
  Process Piping Design Handbook (vol 1 & 2) - by Peter Smith junaid 5 4,440 03-09-2013, 02:29 PM
Last Post: arshiakh
  Piping Systems & Pipeline: ASME Code Simplified cordoba123 1 2,058 03-03-2011, 08:42 AM
  Piping Systems Manual noelda2 1 2,365 02-28-2011, 10:23 AM
  Repair, Retrofit and Inspection of Building Exterior Wall Systems noelda2 4 2,849 02-04-2011, 11:27 AM
