Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) Performance of Lead-Rubber and Sliding Bearings
 garcia
Junior Member
User ID: 31025
Threads: 6
Likes: 24 in 8 posts
Given Likes: 3
03-17-2011, 09:28 AM (This post was last modified: 03-25-2011, 10:39 AM by Grunf.)
Performance of Lead-Rubber and Sliding Bearings under Different Axial Load and Velocity Conditions
[Image: 96192479054001797703.jpg]
By: Gianmario Benzoni, Chiara Casarotti
Report No. SRMD–2006/05-rev3
May 2008
Department of Structural Engineering
University of California, San Diego
La Jolla, California 92093-0085
ABSTRACT:
A series of tests on full scale devices for bridge application were completed. Two types of isolators were considered: lead-rubber bearings and sliding bearings. The main performance characteristics of these devices were already acquired through extensive testing campaigns designed for their specific applications. A more systematic analysis of their performance was considered necessary to enrich the knowledge of the device behavior under different loading conditions. Specifically the focus of this project was to address the effects of the applied axial load, the varying levels of velocity and the repetition of cycles on the performance characteristics. The response variations were analyzed, for a low, medium and high level of applied vertical load, defined based on the design load of the bearing. A large spectrum of testing velocities was applied, ranging from very slow tests (0.254 mm/s) to high speed tests (1270 mm/s). Peak shear force, yield force, stiffness, energy dissipated per cycle, friction coefficient and damping was estimated and compared among the different loading conditions. A specific numerical model, for lead-rubber bearings, able to take into account the effects of strain rate and repetition of cycles, is proposed. The effects of bi-directional motions and of unequal distribution of vertical loads between bearings installed in parallel were also investigated.
Moderator note: thread moved from Bad Posts, redesinged using CivilEA Post Generator, info added
[-] The following 9 users Like garcia's post:9 users Like garcia's post
  • malc, Clouseau, Mohoh77, seriousboy, sodapas, zrilek, kowheng, oanm2000, zainseiya
03-25-2011, 10:41 AM
Uploaded: Mar/25/2011, File Size: 2.18 MB, RAR'd single PDF (paginated, bookmarked, searchable text)
[-] The following 10 users Like Grunf's post:10 users Like Grunf's post
  • kowheng, blaze, zrilek, chenamoy, oanm2000, DamaD, zainseiya, melkat, draluka, ajmf77
  Determination of Additives in Polymers and Rubber TAFATNEB 1 1,581 11-23-2016, 08:57 AM
Last Post: PinkPant
