Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) MANUAL FOR ENGINEERED WOOD CONSTRUCTION
03-07-2011, 07:07 PM
Size: 1.04 MB | Format: PDF | Publisher: APA – The Engineered Wood Association | Year: 1996 | pages: 100
[Image: 94121329498333046605.jpg]
This supplement contains adjustment factors, dimensions, factored resistance, reference strengths and other properties required to design structural glued laminated timber in the LRFD format. In this format, the term “resistance” is used to refer to member capacities (i.e., moment resistance, compression resistance, etc.). This is distinct from the term “strength” which refers to limit state material properties — conceptually a “factored allowable stress.” The member resistance values tabulated in this supplement are to be used in conjunction with the design methodologies provided in AF&PA/ASCE 16-95, Standard for Load and Resistance Factor Design (LRFD) for Engineered Wood Construction.
The reference strengths were derived according to the principles of ASTM D5457-93, Standard Specification for Computing the Reference Resistance of Wood-based Materials and Structural Connections for Load and Resistance Factor Design. The tabulated reference strength values are to be used within the reference end-use conditions defined therein. When the end-use conditions fall outside the range of the reference conditions, the reference values shall be adjusted by the product of applicable adjustment factors as defined in AF&PA/ASCE 16-95 and also provided in this supplement. For unusual end-use conditions, the designer should consult additional literature for possible further adjustments.
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  • stldtls, ISTRAKTURA, mastermind, Dell_Brett, blaze, rezart, jcbv, kowheng, zrilek, Grunf, oanm2000, Ernest0, goober, imatoric, monter, ladjin, warbeast, ajmf77, nowanda, baikur, oscargon
  Engineering Guide to Wood Frame Construction 2004 ed toa011 2 5,614 11-04-2019, 01:33 AM
  NDS National Design Specification for Wood Construction, 2015 Edition bigone 1 2,418 04-07-2017, 08:23 PM
Last Post: ALMF
  Wood and Wood Joints ibg0203 0 1,710 03-02-2016, 04:07 PM
Last Post: ibg0203
  Canadian Wood Frame House Construction babak 2 3,377 06-15-2015, 03:22 PM
Last Post: sinamaleki
  NDS Supplement: Design Values for Wood Construction, 2015 Edition bigone 0 1,692 01-31-2015, 03:54 PM
Last Post: bigone
  APA Engineered Wood Products ykhackhack 0 1,597 07-20-2012, 04:12 AM
Last Post: ykhackhack
  Details for Conventional Wood Frame Construction - American Wood Council Gabemzaman 2 3,338 04-11-2012, 12:47 PM
Last Post: ranger
