Civil Engineering Association eBooks Structural Books Steel STEEL BUILDINGS IN EUROPE by Arcelor Mittal, Peiner Träger and Corus part 3
03-06-2011, 07:02 AM (This post was last modified: 03-06-2011, 07:15 AM by ir_71.)
Size: 0.25 MB | Format: PDF | Year: 2010 | pages: 23
[Image: 71190242285103299421.jpg]
This document describes the connection resistance calculator, created in Excel, for typical, nominally pinned joints used in braced steel frames. It explains the scope of the workbook and lists the National Annexes and languages that are supported in the workbook. A description is given of each of the worksheets and the input information on each sheet. A screenshot of typical output is presented.
Size: 0.2 MB | Format: PDF | Year: 2010 | pages: 38
[Image: 28008230414994919217.jpg]
This guide provides guidance to developers of software for the design of composite beams used in multi-storey buildings, according to the Eurocodes. It covers simply supported beams connected to the concrete slab using shear studs and gives technical requirements. The ULS verifications are to be based on plastic design.
Size: 0.2 MB | Format: PDF | Year: 2010 | pages: 62
[Image: 68404228742918718216.jpg]
This guide is a Model Construction Specification to be used in contract documents for a typical construction project of a single-storey building. Its main objectives are to achieve greater uniformity in steelwork contract specifications in Europe and to provide a guide to specification of appropriate standards for the design, fabrication and erection of steelwork structures for buildings. It deals with structural steelwork designed in accordance with applicable parts of the Eurocode Standards, to be executed in accordance with applicable parts of EN 1090. All the relevant Sections of the model specification are included in an appendix that can be directly copied and used in contracts, with any additional project-specific information that may be required.
Size: 0.46 MB | Format: PDF | Year: 2010 | pages: 61
[Image: 13144473000170138570.jpg]
This publication provides an introduction to the design process for moment-resisting bolted connections in single storey steel framed buildings. It explains that the design process is complex, involving many steps to determine the resistance of individual bolt rows in the tension zone, checking whether the resistance of the bolt group has to be reduced on account of the performance of the connected elements, and evaluating the bending resistance from the tensile resistances of the rows. To simplify design, a series of design tables for standard connections are given, for eaves and apex connections in portal frames, with haunched and un-haunched rafters
[-] The following 23 users Like ir_71's post:23 users Like ir_71's post
  • kowheng, zrilek, blaze, jcbv, nowanda, zainseiya, vvvv, Dell_Brett, seriousboy, vardan, Grunf, cordoba123, toa011, Clouseau, rkce, cristi, Nilupa, baikur, narendra, Draculina, kmmh76, oanm2000, Quantumm
 warbeast
User ID: 20502
Threads: 41
Likes: 716 in 74 posts
Given Likes: 1728
07-10-2012, 10:58 AM
Direct mirror including SINGLE and MULTI story buildings
Enjoy ;)
[-] The following 11 users Like warbeast's post:11 users Like warbeast's post
  • malc, ruaumoko, 3fan, albani, seriousboy, oanm2000, zrilek, agelos100, Quantumm, Dell_Brett, monter
  Design of Steel Structures; Eurocode 3 Part 1.1 UK EDITION gulilero 0 1,739 04-14-2017, 04:13 AM
Last Post: gulilero
  Design of Steel Structures; Eurocode 3 Part 1-1 - 2nd Edition gulilero 0 1,780 04-14-2017, 03:53 AM
Last Post: gulilero
  ECCS No125 - Buckling of Steel Shells, European Design Recommendations, Eurocode 3, Part 1-6 , 5th jcbv 6 3,415 07-09-2015, 03:09 PM
Last Post: monter
  SCI P080: Fire resistant design of steel structures - A handbook to BS 5950: Part 8 ir_71 2 2,636 05-14-2014, 05:33 AM
  SCI P164: Design of Steel Portal Frames for Europe robertsas 3 4,425 02-17-2014, 08:42 AM
Last Post: vinnunsam
