Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 10219:2006 Cold formed welded structural hollow sections of non-alloy and fine
02-28-2011, 06:18 AM (This post was last modified: 02-28-2011, 06:25 AM by ir_71.)
BS EN 10219 - 1:2006 Cold formed welded structural hollow sections of non-alloy and fine grain steels - Part 1: Technical delivery conditions
Author: ECISS/TC 10 | Size: 0.6 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 36
[Image: 83791991557843153099.jpg]
This part of this European Standard specifies the technical delivery conditions for cold formed welded structural hollow sections of circular, square or rectangular forms and applies to structural hollow sections formed cold without subsequent heat treatment. Requirements for tolerances, dimensions and sectional properties are contained in EN 10219-2.
NOTE A range of steel grades is specified in this European Standard and the user should select the grade appropriate to the intended use and service conditions. The grades and mechanical properties of the finished hollow sections are compatible with those in EN 10025-2 and EN 10025-3.
BS EN 10219 - 2:2006 CCold formed welded structural hollow sections of non-alloy and fine grain steels — Part 2: Tolerances, dimensions and sectional properties
Author: ECISS/TC 10 | Size: 0.4 MB | Format: PDF | Publisher: CEN | Year: 2006 | pages: 40
[Image: 09119010401299514111.jpg]
This part of EN 10219 specifies tolerances for cold formed welded circular, square and rectangular structural hollow sections, manufactured in wall thicknesses up to 40 mm, in the following size ranges:
Circular: Outside diameters up to 2 500 mm
Square: Outside dimensions up to 500 mm x 500 mm
Rectangular: Outside dimensions up to 500 mm x 300 mm
The formulae for calculating sectional properties of sections manufactured to the dimensional tolerances of this standard, to be used for the purposes of structural design, are given in Annex B. Dimensions and sectional properties for a limited range of sizes are given in Annex C. Technical delivery conditions are specified in EN 10219-1.
NOTE The designation of the sections' major axis (yy) and its minor axis (zz) align with the axis designation used for structural design in the structural Eurocodes.
  • kowheng, jcbv, blaze, Dell_Brett, toa011, allagui10, oanm2000, zrilek, monter, RobNow, peixoto
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
10-05-2012, 05:52 AM
reposted; all links are dead
or
pass:
or DIN version only part1
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • Jackass, malc, peixoto, chenamoy
 andersen3
User ID: 464
Threads: 54
Given Likes: 1243
11-18-2013, 11:15 AM
new links:
password:
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • Dell_Brett, bogdanobi
 abualamal
Palestine
User ID: 39414
Threads: 19
Likes: 37 in 13 posts
Given Likes: 167
07-14-2015, 06:50 AM (This post was last modified: 07-14-2015, 06:57 AM by abualamal.)
Dear Friends
Below links for the files
Best Regards
[-] The following 6 users Like abualamal's post:6 users Like abualamal's post
  • vvvv, PinkPant, Dell_Brett, oanm2000, zrilek, malc
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
06-03-2019, 09:56 AM
concrete solution advocate
[-] The following 8 users Like concreteok's post:8 users Like concreteok's post
  • kowheng, lisine, pezhmankhan, PinkPant, jcbv, Nita1391, Dell_Brett, mgdario
  BS ISO 14347:2008 Fatigue - Design procedure for welded hollow-section joints - Recom ir_71 2 3,101 06-18-2015, 04:15 AM
  BS 7668:2004 Weldable structural steels — Hot finished structural hollow sections in ir_71 1 2,350 02-18-2013, 12:19 PM
  BS EN 10034:1993 Structural steel I and H sections - Tolerances on shape and dimensio ir_71 1 3,184 02-14-2013, 11:02 AM
  BS EN 10249:1996 Cold formed sheet piling of non alloy steels ir_71 0 1,951 05-13-2011, 12:33 PM
