Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8102:1990 Code of practice for Protection of structures against water from the gro
02-20-2011, 06:09 AM
BS 8102:1990 Code of practice for Protection of structures against water from the ground
Author: Technical Committee CSB/55 | Size: 0.88 MB | Format: PDF | Publisher: BSI | Year: 1990 | pages: 40 | ISBN: 0580178978
[Image: 75145761268993337012.jpg]
This code of practice provides guidance on methods of dealing with and preventing the entry of water from surrounding ground into a building below ground level. The main methods described are the use of applied waterproofing finishes, watertight construction and drained cavity construction. The code does not make any recommendations concerning the use of embedded heating in basements, floors and walls or for the special requirements in connection with the design and construction of cold stores.
NOTE The titles of the publications referred to in this code are listed on the inside back cover.
Dear friends, if somebody of you have the newest edition of this code(from 2009), please share it.
  • kowheng, dbsimon29, ruwan75, usman, melkat, blaze, ssi3k, toa011, zrilek, oanm2000, roaming79, peixoto, vvvv, hodzicemir
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-15-2013, 01:03 PM
link dead; reposted here:
pass:
  • ssobhan, Jackass, Dell_Brett, peixoto, hodzicemir
03-07-2013, 04:13 PM (This post was last modified: 03-07-2013, 04:33 PM by 3fan.)
BS 8102:2009
  • 3fan, Jackass, kowheng, vvvv, malc, Dell_Brett, miquan, knrsa, Trishu999, chenamoy, zrilek, peixoto, hodzicemir
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
03-04-2015, 08:53 AM
I have not downloaded from #3. I believe this is from another source and of picture quality. Hopefully someone downloaded before will share again.
concrete solution advocate
[-] The following 5 users Like concreteok's post:5 users Like concreteok's post
  • PinkPant, malc, Tarik, hodzicemir, Dell_Brett
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
03-25-2015, 07:48 AM
BS 8102:2009 replaces BS 8102:1990, which is now withdrawn. BS 8102:2009 (Original preprint) is posted at the following thread:
[-] The following 6 users Like Mohammad6299's post:6 users Like Mohammad6299's post
  • concreteok, oanm2000, amindoxiti, zrilek, PinkPant, malc
 civGr
Greece
User ID: 174979
Threads: 0
Likes: 0 in 0 posts
Given Likes: 8
02-16-2021, 08:32 PM (This post was last modified: 02-16-2021, 09:42 PM by Dell_Brett.)
Dead link could you please upload new?
 monter
User ID: 31175
Threads: 2
Likes: 664 in 50 posts
Given Likes: 1831
07-31-2021, 07:54 PM
new link for post #1
File Size: RAR/PDF 758 kB/1.1 MB
[-] The following 3 users Like monter's post:3 users Like monter's post
  • Dell_Brett, Wijono, PinkPant
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,225 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,530 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,086 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8102: Protection of below ground structures against water ingress poolmand 0 2,791 05-03-2023, 10:15 AM
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,084 02-12-2022, 08:00 AM
  BS EN 14629:2007 Products and systems for the protection and repair of concrete structures ir_71 2 3,200 02-11-2022, 09:56 AM
Last Post: CAMSECT
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,315 07-31-2021, 08:00 PM
Last Post: monter
