Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 5925:1991 Code of practice for Ventilation principles and designing for natural ve
02-19-2011, 06:17 PM
BS 5925:1991 Code of practice for Ventilation principles and designing for natural ventilation
Author: Technical Committee BDB/2 | Size: 1.32 MB | Format: PDF | Publisher: BSI | Year: 1991 | pages: 48 | ISBN: 0580192857
[Image: 61278615398184699441.jpg]
This British Standard gives recommendations on the principles which should be observed when designing for the natural ventilation of buildings for human occupation. The standard is in three sections, as follows:
Section 1. General
Section 2 outlines the main reasons for the provision of ventilation and, where possible, recommends quantitative air flow rates. It is shown that these form the basis for air supply recommendations for different types of buildings and rooms characterized by usage. The basis for the choice between natural and mechanical ventilation is given. The design of mechanical ventilation systems is dealt with in BS 5720.
Section 3 gives recommendations on the design of natural ventilation systems and on the estimation of air infiltration rates in housing.
Appendix A is a bibliography and reference to publications listed in it are shown as:
(see Appendix A [15]).
Appendix B gives recommendations on evaluating contamination risks.
Appendix C gives recommendations on calculating ventilation rates to reduce the risk of surface condensation under steady state conditions.
Appendix D gives recommendations on determining ventilation requirements.
Appendix E gives recommendations on calculating reference wind speed.
Appendix F gives recommendations on calculating natural ventilation rates for a simple building.
This standard does not attempt to address thermal comfort aspects of ventilation such as indoor air movement, temperature stratification, exact position of ventilation openings etc.
NOTE The titles of the publications referred to in this standard are listed on the inside back cover.
  • usman, melkat, oanm2000, Grunf, kowheng, duazo2009, toa011, zrilek, dbsimon29, ziadjordan, toni, peixoto, asim99
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-20-2013, 08:34 AM
all links dead; reposted here:
password
[-] The following 2 users Like andersen3's post:2 users Like andersen3's post
  • peixoto, Dell_Brett
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,383 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,605 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,258 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,129 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,383 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,749 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,318 02-17-2021, 11:20 AM
Last Post: temp1366
