Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO - Guide Specifications for LRFD Seismic Bridge Design
02-11-2011, 07:16 AM (This post was last modified: 12-30-2011, 04:39 PM by usman.)
AASHTO Guide Specifications for LRFD Seismic Bridge Design
Author: Roy A. Imbsen | Size: 16.19 MB | Format: PDF | Publisher: BSI | Year: 2007 | pages: 236
[Image: 83284730917953231446.jpg]
The AASHTO Guide Specifications for LRFD Seismic Bridge Design is established in accordance with the NCHRP 20-07/Task 193 Task 6 Report. Task 6 contains five (5) Sections corresponding to Tasks 1 to 5 as follows:
SECTION 1 includes a review of the pertinent documents and information that were available.
SECTION 2 presents the justification for the 1000- year return period (which is approximately equivalent to a 7% probability of exceedance in 75 years) as
recommended for the seismic design of highway bridges.
SECTION 3 includes a description of how the “no analysis” zone is expanded and how this expansion is incorporated into the displacement based approach.
SECTION 4 describes the two alternative approaches available for the design of highway bridges with steel superstructures and concludes with a recommendation to use a force based approach for steel superstructures.
SECTION 5 describes the recommended procedure for liquefaction design to be used for highway bridges. This aspect of the design is influenced by the recommended design event and the no analysis zone covered in Tasks 2 and 3, respectively. The recommendations proposed are made taking into account the outcome of these two tasks for Seismic Design
Category D. The following recommendations are documented:
Task 2
1. Adopt the 7% in 75 years design event for development of a design spectrum.
2. Ensure sufficient conservatism (1.5 safety factor) for minimum support length requirement. This conservatism is needed to enable to use the reserve capacity of hinging mechanism of the bridge system. This conservatism shall be embedded in the specifications to address unseating vulnerability. At a minimum it is recommended to embed this safety factor for sites outside of California.
3. Partition Seismic Design Categories (SDC’s) into four categories and proceed with the development of analytical bounds using the 7% in 75 years design event.
[-] The following 24 users Like ir_71's post:24 users Like ir_71's post
  • melkat, Dell_Brett, cace-01, kowheng, toa011, jf28, lednar_ved, cve_jule, oanm2000, ilgar, seriousboy, Adam Smith, usman, jcoronellr, essam2109, yantonegr, prasat, adhikarig, triance, ruaumoko, ting tsai huang, rigid_joint, bigone, Rapaig
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
01-26-2014, 04:35 PM
AASHTO Guide Specifications for LRFD Seismic Bridge Design, 1st ed, 2009
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  • Dell_Brett, bigone, Rapaig, rigid_joint, kristoffer_89
 junaid
User ID: 402
Threads: 209
Likes: 8,170 in 732 posts
Given Likes: 983
01-26-2014, 04:44 PM
AASHTO - Guide Specifications for LRFD Seismic Bridge Design, 2nd Edition, 2011
[-] The following 18 users Like junaid's post:18 users Like junaid's post
  • oanm2000, cace-01, sodapas, Dell_Brett, malc, Evandrojr, bigone, adhikarig, rigid_joint, nickycruz, utan, ali akbar, amindoxiti, i_kabir, Mohammad6299, blaze, Wijono, kowheng
 i_kabir
Bangladesh
User ID: 741
Threads: 121
Likes: 3,231 in 259 posts
Given Likes: 446
07-09-2014, 05:06 PM
AASHTO Guide Specifications for LRFD Seismic Bridge Design (2nd Edition)
Author: AASHTO | Size: 4.8 MB | Format: PDF | Quality: Original preprint | Publisher: American Association of State Highway and Transportation Officials | Year: 2011 | pages: 266 | ISBN: 9781560515210
[Image: 56950690072860668976.jpg]
Covers seismic design for typical bridge types and applies to non-critical and non-essential bridges. Approved as an alternate to the seismic provisions in the AASHTO LRFD Bridge Design Specifications. Differs from the current procedures in the LRFD Specifications in the use of displacement-based design procedures, instead of the traditional force-based R-Factor method. Includes detailed guidance and commentary on earthquake-resisting elements and systems, global design strategies, demand modeling, capacity calculation, and liquefaction effects. Capacity design procedures underpin the Guide Specifications' methodology; includes prescriptive detailing for plastic hinging regions and design requirements for capacity protection of those elements that should not experience damage.
[-] The following 23 users Like i_kabir's post:23 users Like i_kabir's post
  • oanm2000, vardan, cace-01, Mohammad6299, Dell_Brett, malc, bridgeengineer, ibg0203, Jackass, utan, pezhmankhan, sodapas, PinkPant, slowet, Rapaig, inge911, davegabj, Wijono, bigone, uncblue, lesgiu, kristoffer_89, kowheng
02-12-2015, 02:16 PM
AASHTO Guide Specifications for Seismic Bridge Design
Author: Roy A Imbsen; American Association of State Highway and Transportation Officials. Subcommittee on Bridges and Structures | Size: 4.7 MB | Format: PDF | Quality: Unspecified | Year: 2009 | pages: 266
[Image: 09653264071956939693.jpg]
  • PinkPant, Dell_Brett, cace-01, bigone, gulilero, subin91, carolinandra, Mohammad6299, blaze, kowheng
 Rapaig
User ID: 20672
Threads: 7
Likes: 119 in 16 posts
Given Likes: 160
02-13-2015, 02:56 AM (This post was last modified: 02-13-2015, 02:57 AM by Rapaig.)
Version 2007
Version 2009
Version 2011
[-] The following 10 users Like Rapaig's post:10 users Like Rapaig's post
  • gulilero, Dell_Brett, PinkPant, jcbv, oanm2000, bridgeengineer, Mohammad6299, nibbi, blaze, kowheng
01-25-2022, 06:47 AM (This post was last modified: 01-25-2022, 06:50 AM by poolmand.)
AASHTO Guide Specifications for Seismic Bridge Design, 2ned edition
Author: AASHTO | Size: 4.17 MB | Format: PDF | Quality: Original Preprint | Year: 2011 | pages: 266 | ISBN: 9781560513964 , 1560513969
  • Aviator, Dell_Brett, babakfeyzi, oanm2000
  AASHTO LRFD Bridge Design Specifications 10th edition pezhmankhan 3 8,886 02-01-2025, 08:35 AM
  AASHTO M351: Standard Specification for Cotton Duck Fabric Bridge Bearings, poolmand 0 2,895 01-15-2024, 08:42 AM
  AASHTO LRFD Bridge Design Guide Specifications for GFRP-Reinforced Concrete poolmand 0 2,925 08-30-2023, 08:45 AM
  AASHTO LRFD Bridge Construction Specifications asim99 4 4,576 02-09-2022, 09:14 AM
Last Post: i_kabir
  AASHTO: Guide to Wetland Mitigation Issues for Transportation Designers poolmand 0 2,685 01-26-2022, 06:06 AM
  AASHTO: Practical Guide to Cost Estimating poolmand 0 2,754 01-26-2022, 05:46 AM
  AASHTO Manual for Bridge Element Inspection carolinandra 1 3,580 01-25-2022, 11:46 AM
