Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 5493:1977+A2 Code of practice for Protective coating of iron and steel structures
02-11-2011, 06:51 AM
BS 5493:1977+A2 Code of practice for Protective coating of iron and steel structures against corrosion
Author: Committee B/209 | Size: 2.15 MB | Format: PDF | Publisher: BSI | Year: 1993 | pages: 142 | ISBN: 0580095657
[Image: 62153764490133363361.jpg]
This code classifies recommended methods of protection against corrosion of iron and steel structures exposed to environments commonly encountered. It describes the various methods in detail and gives guidance on how to specify a chosen protective system, how to ensure its correct application, and how it should be maintained. The code does not include specific recommendations for ships, vehicles, offshore platforms, specialized chemical equipment, or cladding materials; nor does it include detailed recommendations for plastics
coatings or cement-mortar linings. For some situations, weathering steel may be an alternative to ordinary structural steel with applied coatings. No detailed recommendations on the use of weathering steels are given in this code and when their use is contemplated, advice should be sought from the steel industry.
  • kowheng, monter, Dell_Brett, kmmh76, toa011, jcbv, oanm2000, Adam Smith, roaming79, usman, duazo2009, zrilek, dbsimon29, peixoto
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
02-18-2013, 12:28 PM
links dead; reposted here:
[-] The following 4 users Like andersen3's post:4 users Like andersen3's post
  • malc, knrsa, peixoto, Dell_Brett
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,380 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,600 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,246 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,129 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,383 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 4,747 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,317 02-17-2021, 11:20 AM
Last Post: temp1366
