Civil Engineering Association eBooks Codes, Manual & Handbook AS/NZS 4672:2007 Parts 1 and 2 Steel prestressing materials
12-22-2010, 05:49 AM (This post was last modified: 12-22-2010, 05:54 AM by ir_71.)
Author: Joint Technical Committee BD-084 | Size: 0.8 MB | Format: PDF | Publisher: Standards Australia/Standards New Zealand | Year: 2007 | pages: 49 | ISBN: 0 7337 7984 0
[Image: 79544097404456397439.jpg]
This Standard specifies requirements for high tensile strength steel tendons to be used for
prestressing concrete and for other similar purposes (e.g., masonry structures). It applies
only to tendons in the condition as supplied by the manufacturer. It does not cover
requirements for anchorage devices (see Note 1) and materials used in conjunction with the
prestressing steel in structural components.
The specific properties for each type of prestressing steel are given in Sections 2 to 6,
namely:
(a) Section 2, As-drawn (mill coil) wire.
(b) Section 3, Stress-relieved wire.
© Section 4, Quenched and tempered wire.
(d) Section 5, Strand.
(e) Section 6, Hot-rolled bars with or without subsequent processing.
NOTES:
1 Anchorage devices are covered by AS/NZS 1314.
2 Advice and recommendations on information to be supplied by the purchaser at the time of
enquiry and order are contained in the purchasing guidelines set out in Appendix A.
Author: Joint Technical Committee BD-084 | Size: 0.6 MB | Format: PDF | Publisher: Standards Australia/Standards New Zealand | Year: 2007 | pages: 21 | ISBN: 0 7337 7985 9
[Image: 28715426656109378536.jpg]
This Standard sets out the minimum rate of testing of wire, strand and bar for prestressing
of permanent structures necessary to comply with the requirements of AS/NZS 4672.1.
NOTE: Manufacturing control should apply to all aspects of production from steel melting to the
dispatch of the final product.
  • kowheng, axee1980, usman, blaze, jcbv, Dell_Brett, ilgar, sivlad, arceon
  Australian Standard AS 1391—2007 Metallic materials—Tensile testing at ambient temper ir_71 1 2,886 01-11-2020, 09:11 AM
  Handbook of Materials Modeling parts A and B ir_71 1 2,263 12-02-2010, 06:24 AM
