Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12843:2004 Precast concrete products - Masts and poles
10-27-2010, 07:49 AM (This post was last modified: 11-19-2010, 07:26 PM by Grunf.)
This Standard specifies requirements for precast concrete poles (also commonly called masts) (either all of a piece or composed of elements), reinforced and/or prestressed as structural elements; they may be hollow or solid and may receive or include additional components (e.g. cross-arms, platforms etc.), inserts and connectors. Additional elements may be connected to pole elements.
Structures made from such elements in mono- or multi-legged form may be used for :
- overhead electrical lines ;
- telecommunication lines ;
- overhead electrical lines for railways, trams and similar ;
- supports for lighting ;
- supports for loudspeaker installation ;
- antenna and telecommunication poles ;
- supports for wind turbines ;
- and similar installations.
This Standard does not cover lighting columns for use in traffic circulation areas.
:JC_cheers:
  • rendel_©, vvvv, ssi3k, Grunf, Dell_Brett, vardan, peixoto, roaming79, avscorreia, kowheng, oanm2000, ziggywas1, chenamoy, toa011, sivlad
04-13-2011, 04:58 AM
New links:
IR
  • malc, blaze, concreteok, toa011, oanm2000, st77bel, shaker, zrilek, kmmh76, adshrt, sivlad, versiondemo
03-02-2014, 07:40 PM
  • Mohammad6299, Dell_Brett, jcbv, vvvv, PinkPant, dizz
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 50
Likes: 4,962 in 637 posts
Given Likes: 3500
01-24-2015, 01:19 AM
concrete solution advocate
[-] The following 6 users Like concreteok's post:6 users Like concreteok's post
  • dinu69in, Dell_Brett, PinkPant, bridgeengineer, oanm2000, CAMSECT
  EN 13369:2004 (Common rules for precast concrete products) raffah 2 3,335 03-07-2018, 01:53 PM
  EN 10204:2004 Metallic products - Types of inspection documents ir_71 1 2,544 04-11-2014, 04:33 AM
  EN 14992:2007 Precast concrete products - Wall elements ir_71 1 2,670 01-20-2014, 03:27 PM
Last Post: milova
  EN 12794:2005 Precast concrete products - Foundation piles ir_71 1 2,614 04-11-2013, 01:59 AM
Last Post: st77bel
  EN 10168:2004 Steel products - Inspection documents - List of information and descrip ir_71 0 2,134 01-23-2011, 07:37 AM
  EN 15037 Precast Concrete Products. Beam-and-block floor systems ir_71 0 2,112 12-14-2010, 04:02 AM
  EN 14843:2007 Precast concrete products - Stairs ir_71 2 2,982 10-29-2010, 04:55 PM
