Civil Engineering Association eBooks Structural Books Concrete Minimum Reinforcement in Concrete Members
 abudabeeja
User ID: 1245
Threads: 496
Likes: 10,106 in 672 posts
Given Likes: 1271
06-17-2009, 02:08 AM (This post was last modified: 09-25-2010, 03:10 PM by Grunf.)
Minimum Reinforcement in Concrete Members, Volume 24 (European Structural Integrity Society)
[Image: 63424316029527781092.jpg]
A. Carpinteri (Author)
Product Details:
* Hardcover: 212 pages
* Publisher: Elsevier Science (May 6, 1999)
* Language: English
* ISBN-10: 0080430228
* ISBN-13: 978-0080430225
Product Description:
The ESIS-Technical Committee 9 on Concrete was established in 1990 and has met seven times. A proposal was put to European and extra-European laboratories entitled "Scale effects and transitional failure phenomena of reinforced concrete beams in flexure" which lead to several positive responses.
The central topic discussed by the committee was that of the minimum reinforcement in concrete members. The minimum amount of reinforcement is defined as that for which "peak load at first concrete cracking" and "ultimate load after steel yielding" are equal. In this way, any brittle behaviour is avoided as well as any localized failure, if the member is not over-reinforced. In other words, there is a reinforcement percentage range, depending on the size-scale, within which the plastic limit analysis may be applied with its static and kinematic theorems.
Carpinteri, Ferro, Bosco and El-Katieb propose a LEFM model, according to which reinforcement reactions are applied directly on the crack surfaces and a compatibility condition is locally imposed on the crack opening displacement in correspondence with the reinforcement. The theoretical model is found to provide a satisfactory estimate of the minimum percentage of reinforcement that depends on the scale and enables the element in flexure to prevent brittle failure.
.jpg   minimum reinforcement in conc member.jpg (Size: 25.04 KB / Downloads: 45)
[-] The following 28 users Like abudabeeja's post:28 users Like abudabeeja's post
  • Dell_Brett, Dell_Brett, simanta, simanta, paulocs, paulocs, oanm2000, oanm2000, zrilek, zrilek, sangam, sangam, deltalead, eficivil, cristi, AK12, Grunf, engr1900, fnoto, ajmf77, dinu69in, Nilupa, Badis, salahcivil, michaelsoe, rudyhera03, levanduy, K.Lee
 virgo958
User ID: 225
Threads: 0
Likes: 9 in 1 posts
Given Likes: 0
09-25-2010, 01:00 PM (This post was last modified: 09-25-2010, 01:10 PM by Dell_Brett.)
New Link
Moderator note:
To see how to protect a link, goes to:
[-] The following 9 users Like virgo958's post:9 users Like virgo958's post
  • shaqee, oanm2000, jcoronellr, cve_jule, nigema, DamaD, cowboy, malc, kirananvekar
09-25-2010, 03:14 PM
Mirror link:
Password:
If you like the book, we strongly suggest you to buy it. Support the authors.
[-] The following 9 users Like Grunf's post:9 users Like Grunf's post
  • toa011, cve_jule, igor1234, eng_ismail, cordoba123, planeti_x, chenamoy, draluka, ali akbar
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
07-20-2014, 07:01 PM
[-] The following 26 users Like Mohammad6299's post:26 users Like Mohammad6299's post
  • vardan, rezart, ssobhan, gulilero, jfjdm, zrilek, bridgeengineer, blaze, ykhackhack, mgdario, malc, subin91, viet2010, Jackass, ibg0203, techno, learner20, sodapas, eliseo.as, cristi, dizz, ruaumoko, Dell_Brett, milova, melekeen, thangbomkhung
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
10-21-2016, 03:01 PM
[-] The following 18 users Like lisine's post:18 users Like lisine's post
  • Jackass, mgdario, Dell_Brett, PinkPant, bridgeengineer, blaze, cace-01, slowet, rezart, oanm2000, dizz, zrilek, heogay43, K.Lee, Aviator, draluka, bao2004, febo927
  Reinforcement Detailing Handbook for Reinforced and Prestressed Concrete carolinandra 0 1,649 01-29-2022, 08:01 PM
Last Post: carolinandra
  Fiber-Reinforced Polymer: Reinforcement for Concrete Structures abudabeeja 1 2,761 05-21-2019, 06:35 AM
  Strengthening of Concrete Structures with Adhesive Bonded Reinforcement cace-01 4 3,491 03-12-2017, 09:37 PM
Last Post: Veggeta
  Handbook on Concrete Reinforcement and Detailing hazus 3 4,765 02-27-2016, 09:15 PM
Last Post: scorpion07
  FIB 10:Bond of reinforcement in concrete arshiakh 1 2,467 12-01-2014, 09:28 AM
  Design of High Strength Concrete Members (Mendis) durden 1 2,368 06-12-2014, 11:49 AM
Last Post: subin91
  Developments in the formulation and reinforcement of concrete >> Edited by S Mindes cordoba123 1 2,583 09-04-2013, 09:56 AM
Last Post: f_slikken
