Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Autodesk Robot Structural Analysis 2011 bug
 RazvanMelek
User ID: 26357
Threads: 8
Likes: 203 in 28 posts
Given Likes: 23
08-12-2010, 01:40 PM (This post was last modified: 08-12-2010, 01:52 PM by kowheng.)
I don't really know what is going on, but i can't seem to use library typical structures in autodesk robot structural analysis.When I select the type, for example, a predefined truss of some sort in the Typical Structures dialog I press OK and then a dialog appears that has some customisable parameters for the structure.After I finish and press OK it displays the following dialog "Errors in the file Do you want to see them?" and if I click on yes it displays the syntax for the library file used(in my case the 2D triangular truss).Can anybody please help me?I have been googling for a solution for days,you can say that I'm at wits end. :dash2:
PS:PRTSCR's of the error included:
[Image: 69913355.jpg]
[Image: 62608215.jpg]
 Rafacascudo
User ID: 7173
Threads: 4
Likes: 10 in 7 posts
Given Likes: 36
08-13-2010, 01:57 PM
no problems here. Try inputting the default parameters suggested by the library tabs and see if it works
 RazvanMelek
User ID: 26357
Threads: 8
Given Likes: 23
08-14-2010, 06:56 AM
(08-13-2010, 01:57 PM)Rafacascudo Wrote: no problems here. Try inputting the default parameters suggested by the library tabs and see if it works
I have tried setting the parameters I want by replacing the ones in the file.Thing is that the program doesn't seem to insert anything even after modding the file.I suspect that the library file is not properly accesed by Robot.Could this be like a framework problem?Does Robot require any additional frameworks to run on or any special privileges?Has anybody encountered this problem?
  How to introduce P delta effect in Robot Structural Analysis Professional Ver. 2010 uev_482 1 4,848 09-16-2010, 03:51 PM
Last Post: allagui10
  robot spread sheet calculator 2011 rohailiyaz 23 29,282 09-06-2010, 07:54 PM
Last Post: czesio
  EXpert BA Autodesk Robot Structural Analysis 2010 sofien.enit 1 5,956 07-05-2010, 07:36 AM
Last Post: giga
  Robot Structural Analysis CBS rohailiyaz 2 6,099 05-10-2010, 01:03 PM
Last Post: ruwan75
  Deleting user defined sections in Robot Structural Analysis bluefish80 0 4,790 12-21-2009, 11:41 AM
Last Post: bluefish80
