Civil Engineering Association eBooks Codes, Manual & Handbook CSA CSA W59: Welded Steel Construction
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
07-27-2010, 04:27 AM (This post was last modified: 05-01-2024, 07:14 AM by Administrator.)
CSA W59-03 - Welded Steel Construction - Metal Arc Welding
Canadian Standards Association
[Image: 93680755808355543707.gif]
[Image: 82949465268019027268.gif]
[Image: 87370871433312741885.gif]
[Image: 75380471509336214062.gif]
The Canadian Standards Association web page:
[-] The following 12 users Like usman's post:12 users Like usman's post
  • kowheng, blacktony, jcbv, Dell_Brett, robertsas, super_engineer, passenger, pezhmankhan, hcardenas, Nilupa, ambrish, gulilero
Likes: 12,073 in 1,233 posts
09-26-2020, 08:31 AM
[-] The following 9 users Like pezhmankhan's post:9 users Like pezhmankhan's post
  • Dell_Brett, chandra1234567, zrilek, blaze, babakfeyzi, carolinandra, RICARDI, subin91, PinkPant
 malee
User ID: 554
Threads: 17
Likes: 1,358 in 98 posts
Given Likes: 267
09-27-2020, 02:22 AM
[-] The following 8 users Like malee's post:8 users Like malee's post
  • CAMSECT, mgdario, jcbv, Dell_Brett, oanm2000, caifan, PinkPant, Wijono
04-14-2024, 12:43 PM
CSA W59-24: Welded steel construction
| Size: 60.86 MB| Format: PDF| Quality: Scanner| Publisher: CSA Group| Year: 2024
[Image: 66642189440561935895.jpg]
Preface This is the eleventh edition of CSA W59, Welded steel construction . It supersedes the previous editions published in 2018, 2013, 2003, 1989, 1984, 1982, 1977, 1970, 1946, and 1940. The following are the most significant changes to this edition of the Standard: a) Clause 3 has been revised to add several steels to the prequalified list. b) Clause 5 has been updated to add clarification on the requirements related to hydrogen designators. c) Clause 7 has been reworked to provide clarity on roles and responsibilities for welding inspection. d) Clause 8 includes corrections related to terminology, equipment, and flaw length sizing. Calibration requirements have been revised to reflect digital instrumentation. Allowances for the use of an alternative ultrasonic technique and radiographic imaging systems have been added. e) In Clause 10, all the figures have been reworked into a new format which arranges prequalified joint-by-joint type rather than by welding process. f) As this Standard contains no commentary, various non-mandatory annexes have been included to generate a better understanding of certain aspects of welded steel construction. The annexes of the previous edition of this Standard have generally been reviewed for clarity. In addition, i) Annex O has been added to define welding of cast steels for structural applications; ii) Annex W has been added to provide additional requirements for welding consumables, welded fabrication techniques, weld repairs, demand critical welds and welding inspection for seismic-force resisting system (SFRS) of structures; and iii) Annex X has been added to define an alternative ultrasonic examination technique for manual conventional and manual phased array ultrasound. New acceptance criteria were developed for equivalent sensitivity to the fixed attenuation (Clause 8.2) technique. g) Annex Y has been added to define ultrasonic examinations of groove welds using time-corrected gain technique with encoded phased array ultrasonic testing. This Standard was prepared by the Technical Committee on Welding of Bridges, Buildings, and Machinery and the Offshore Welding Task Group, under the jurisdiction of the Strategic Steering Committee on Construction and Civil Infrastructure, and has been formally approved by the Technical Committee. Scope 1.1 This Standard covers welding requirements for carbon and low-alloy welded steel construction, with the exception of those types listed in Clause 1.2. Requirements that are essentially common to all such structures are covered in Clauses 3 to 10, while provisions applying specifically to statically-loaded structures and to cyclically-loaded structures are included in Clauses 11 and 12, respectively. 1.2 This Standard is not intended to apply to pressure vessels or to structures governed by special codes such as those of the American Petroleum Institute, the American Society of Mechanical Engineers, or the American Water Works Association. 1.3 This Standard includes provisions for the following: a) shielded metal arc welding (SMAW); b) submerged arc welding (SAW); c) gas metal arc welding (GMAW); d) gas tungsten arc welding (GTAW); e) flux-cored arc welding (FCAW); f) metal-cored arc welding (MCAW); g) electroslag welding (ESW); h) electrogas welding (EGW); and i) stud welding (SW) processes. 1.4 The provisions of this Standard are not intended for use with steels having a specified minimum yield strength over 700 MPa (100 000 psi). 1.5 This Standard applies to the welding of base metals 3 mm (1/8 in) and thicker. In cases where base metals less than 3 mm (1/8 in) thick are to be welded to base metals 3 mm (1/8 in) and thicker, the requirements of AWS D1.3/AWS D1.3M and this Standard apply. In the case of any conflict between AWS D1.3/AWS D1.3M and this Standard, the requirements of this Standard govern. Notes: 1) In cases where base metals less than 3 mm (1/8 in) thick are to be welded to base metals less than 3 mm (1/8 in), the requirements of AWS D1.3/AWS D1.3M may be appropriate. 2) See CSA W47.1, Annex J, for guidance related to the qualification of welding personnel and welding procedures for sheet steel. 1.6 This Standard does not address safety problems associated with welding and welding practices. Note: CSA W117.2 addresses safety in welding, cutting, and allied processes, and should be followed in addition to any applicable workplace health and safety legislation in effect. It is the responsibility of the user of this Standard to establish appropriate safety and health practices and to determine the applicability of regulatory limitations prior to use. 1.7 This Standard does not address the welding of stainless steels. For welding of stainless steel, the provisions of AWS D1.6/AWS D1.6M may be used for the design of welded connections, prequalification, fabrication, and inspection. Note: See CSA W47.1, Annex K, for guidance related to the qualification of welding personnel and welding procedures for stainless steel. 1.8 This Standard does not address underwater welding activities. 1.9 In this Standard, \"shall\" is used to express a requirement, i.e., a provision that the user is obliged to satisfy in order to comply with the Standard; \"should\" is used to express a recommendation or that which is advised but not required; and \"may\" is used to express an option or that which is permissible within the limits of the Standard. Notes accompanying clauses do not include requirements or alternative requirements; the purpose of a note accompanying a clause is to separate from the text explanatory or informative material. Notes to tables and figures are considered part of the table or figure and may be written as requirements. Annexes are designated normative (mandatory) or informative (non-mandatory) to define their application. 1.10 The values given in SI units are the units of record for the purposes of this Standard. The values given in parentheses are for information and comparison only.
  • babakfeyzi, Dell_Brett, PinkPant, Batman07, jcbv
  [CivilEA Exclusive] CSA W59.2: Welded aluminum construction poolmand 1 3,899 05-07-2024, 09:30 AM
