Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Piled Raft Journal Request
[Request] Piled Raft Journal Request
 xmlnzk
User ID: 18585
Threads: 6
Likes: 1 in 1 posts
Given Likes: 21
06-25-2010, 04:37 PM (This post was last modified: 06-11-2012, 10:04 AM by lisine.)
I'm looking into these journals below
Mandolini, A. and Viggiani, C. (1997). Settlement of piled foundations. Géotechnique 47, No.4, 791-816
Poulos, H. G. (2001). Piled raft foundations: design and applications. Géotechnique 51, No. 2,95-113
With best regards
 mary
User ID: 31558
Threads: 65
Likes: 341 in 77 posts
Given Likes: 692
06-10-2012, 10:58 AM
Author: H. G. Poulos | Source: Géotechnique | Volume : 51, Issue 2, 01 March 2001 | pages :95 –113 | ISSN: 0016-8505 | E-ISSN: 1751-7656
Abstract :
In situations where a raft foundation alone does not satisfy the design requirements, it may be possible to enhance the performance of the raft by the addition of piles. The use of a limited number of piles, strategically located, may improve both the ultimate load capacity and the settlement and differential settlement performance of the raft. This paper discusses the philosophy of using piles as settlement reducers and the conditions under which such an approach may be successful. Some of the characteristics of piled raft behaviour are described. The design process for a piled raft can be considered as a three-stage process. The first is a preliminary stage in which the effects of the number of piles on load capacity and settlement are assessed via an approximate analysis. The second is a more detailed examination to assess where piles are required and to obtain some indication of the piling requirements. The third is a detailed design phase in which a more refined analysis is employed to confirm the optimum number and location of the piles, and to obtain essential information for the structural design of the foundation system. The selection of design geotechnical parameters is an essential component of both design stages, and some of the procedures for estimating the necessary parameters are described. Some typical applications of piled rafts are described, including comparisons between computed and measured foundation behaviour.
[-] The following 1 user Likes mary's post:1 user Likes mary's post
  • techno
 mary
User ID: 31558
Threads: 65
Given Likes: 692
02-11-2013, 08:26 PM
  • blaze
  [REQUEST] piled raft papers from ICE Library mary 3 2,627 05-21-2017, 01:25 PM
Last Post: xnr09
  Journal of Hydrologic Engineering paper request Wolverine883 1 1,560 10-22-2014, 07:33 AM
Last Post: ska51
  [REQUEST] paper request from Springer Journal ska51 3 2,175 09-11-2014, 01:57 PM
Last Post: Mohammad6299
  [REQUEST] Paper request from Environmental Hazards Journal ska51 1 1,626 07-22-2014, 07:28 AM
  [REQUEST] 3D finite elements analysis of vertically loaded composite piled raft siamakdie 1 1,730 12-16-2013, 11:19 AM
  [REQUEST] Centrifuge modelling of piled raft foundations on clay ssobhan 1 1,807 11-29-2013, 02:39 PM
Last Post: mary
  Journal Article Request cyuc 3 2,517 11-24-2013, 04:48 PM
Last Post: DamirDz
