Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering SIMPLIFIED EQUATIONS FOR ESTIMATING THE PERIOD OF VIBRATION OF EXISTING BUILDINGS
 ivanveliki
User ID: 1250
Threads: 47
Likes: 886 in 110 posts
Given Likes: 480
04-22-2009, 06:56 PM
First European Conference on Earthquake Engineering and Seismology
(a joint event of the 13th ECEE & 30th General Assembly of the ESC)
Geneva, Switzerland, 3-8 September 2006
Authors
Helen CROWLEY and Rui PINHO
SUMMARY
Currently, seismic design of new European buildings follows a force-based approach, whilst the assessment of existing buildings is moving towards a displacement-based philosophy. In forcebased design, conservative estimates of the period of vibration should be produced such that the base shear force will be conservatively predicted from an acceleration spectrum, and thus the use of gross section (uncracked) stiffness in analytical calculations is perhaps acceptable. For the assessment of buildings, the use of the uncracked stiffness in the determination of the period is certainly inappropriate considering cracking of critical elements such as beams generally occurs under gravity loading alone. Even if cracking is not found to have occurred before the design seismic level of excitation (considered unlikely as this level of excitation would with all probability have been preceded by a number of lower intensity events), it will occur early on in the response to excitation and thereafter the stiffness will reduce rapidly leading to the loss of the tension stiffening effect of the concrete. Thus, the reliable stiffness of the members of an existing RC frame can only be confidently taken as the yield/cracked stiffness. The uncracked and yield period of existing European reinforced concrete buildings of varying height is analytically calculated herein using eigenvalue analysis. A simplified equation is proposed to relate the yield period of vibration of existing buildings to their height for use in large-scale vulnerability assessment applications.
[-] The following 22 users Like ivanveliki's post:22 users Like ivanveliki's post
  • Administrator , Administrator , oanm2000, oanm2000, Grunf, Grunf, paulocs, paulocs, hmwere, spat, ISTRAKTURA, dinu69in, Jackass, malc, ting tsai huang, slowet, salahcivil, gulilero, Mouh@ndiss, zrilek, giga, TAFATNEB
12-05-2011, 07:35 PM
[Image: comments.png]
Uploaded: Dec/05/2011, File Size: 265.1 kB, PDF, Paginated, Searchable text.
[-] The following 7 users Like Grunf's post:7 users Like Grunf's post
  • Dell_Brett, chrono146, 3fan, yantonegr, engrezi, gulilero, giga
  Seismic assessment of existing buildings (Parts A to C) poolmand 1 1,673 02-27-2023, 10:25 PM
Last Post: sandeepb
  Seismic Rehabilitation Methods for Existing Buildings carolinandra 0 1,478 09-12-2020, 10:22 PM
Last Post: carolinandra
  Simplified Dynamic Analysis of High-Rise Buildings amindoxiti 0 1,652 05-03-2019, 03:31 PM
  Vibration Theory and Applications with Finite Elements and Active Vibration Control bridgeengineer 0 1,507 04-18-2016, 06:33 AM
Last Post: bridgeengineer
  Seismic Assessment and Rehabilitation of Existing Buildings cace-01 1 1,922 08-07-2014, 02:07 PM
Last Post: al_frd
  Review of Documents on Seismic Evaluation of Existing Buildings TAFATNEB 0 1,529 09-02-2013, 08:20 PM
  NRCC Guidelines for Seismic Evaluation of Existing Buildings gulilero 1 1,986 03-22-2013, 05:33 PM
Last Post: arshiakh
